#include <ESP8266_Lib.h>
char auth[] = "eb072d5fba39400596b7084397e37597";
char ssid[] = "Nak";
char pass[] = "1234567890";
//#define EspSerial Serial1
#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
const int relay_pin = 12;
const int ldr_pin = 2;
const int lamp = 13;
void setup(){
pinMode(ldr_pin,INPUT);
pinMode(relay_pin,OUTPUT);
pinMode(lamp,OUTPUT);
Blynk.begin(auth, wifi, ssid, pass);}
void loop(){
int value_ldr = digitalRead(ldr_pin);
Serial.println(value_ldr);
if(value_ldr==HIGH){
digitalWrite(relay_pin,HIGH);
digitalWrite(lamp,HIGH);
else {
digitalWrite(relay_pin,LOW);
digitalWrite(lamp,LOW);
i have try this code is working fine without the blynk code inside. but when i include the blynk code the program seems to b not working. even the arduino board is not connected to the internet. i have follow from the example on code to connect to internet
