USB Serial for Arduino Micro - help needed
Hi
I try to have an Arduino Micro blynking via USB Serial. Below is the code and I followed the guidelines running the script.
It seems that I get connected to the blynk cloud ( DSR is OFF: what does this mean? ) however on my phone i get the info the Arduino Micro is offline.
I have a Blynk Board from Sparkfun running which updates data nicely.
What am I doing wrong…
Thx, Gernot
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  =>          USB HOWTO: http://tiny.cc/BlynkUSB
  This example shows how value can be pushed from Arduino to
  the Blynk App.
  WARNING :
  For this example you'll need SimpleTimer library:
    https://github.com/jfturcot/SimpleTimer
  Visit this page for more information:
    http://playground.arduino.cc/Code/SimpleTimer
  App project setup:
    Value Display widget attached to V5
char auth[] = "XXX656ef096e4980b70e825c9c592XXX";
void myTimerEvent()
  Blynk.begin(Serial, auth);
and after pressing the reset on Arduino Micro the log in the cmd will update
Comment out this line, as it interferes with the USB link, and you can’t use it anyhow for same reason.
// #define BLYNK_PRINT Serial
Thanks @Gunner
Just tried but no success
Your hardware connects fine, no doubt about that. Did you double check the Auth token?
Also, this line is called twice… not sure if that could interfere, but remove one of them anyhow.
Thanks @Gunner that saved me another evening & many frustrations :slight_smile:
