USB Serial Arduino, Rasberry local server Issues (Adress already in use)
Where Can I go to get help for my project which involves Interconnected Arduino over Serial (Hub) USB Running on a local Raspberry B Server?
I think there is a error in my socat/ local server configuration / or sketch because the local server is running and the iOS App is able to connect to the server but I get the message that the device is offline.
I want to get this running first and then start learning with the coding itself.
I am willing to pay for assistance because it came to a point where it is frustrating.
Where should I go?
many thanks!
Sounds like the server is up and running.
What code are you running on the Arduino? Is the Arduino connected via USB to the Pi or to another computer? You will need the blynk-ser script to connect the USB serial device to Blynk server.
I really appreciate your response.
yes the Arduino Board is directly connected to the Raspberry Local Blink server via USB.
The RaspberryB Server is connected via Ethernet to the Router.
The Raspberry has no Display or keyboard, everything works over the installed VNC Server.
yes i installed the blynk-ser script.
pi@raspberrypi:~/Arduino/libraries/Blynk/scripts $ ./blynk-ser.sh
Warning: Server connection may be insecure!
[ Press Ctrl+C to exit ]
Connecting: TCP-LISTEN:8442,reuseaddr,fork,nodelay <-> TCP:10.0.0.5:8442,nodelay
2017/11/07 21:48:11 socat[3453] E bind(5, {AF=2 0.0.0.0:8442}, 16): Address already in use
2017/11/07 21:48:11 socat[3453] N exit(1)
Reconnecting in 3s...
when running “nano /home/pi/Arduino/libraries/Blynk/scripts/blynk-ser.sh” i get:
#!/bin/bash
# Detect script path
pushd `dirname $0` > /dev/null
SCRIPTPATH=`pwd`
popd > /dev/null
# === Edit default options to match your need ===
FROM_TYPE="TCP" # SER, TCP
TO_TYPE="TCP"   # TCP, SSL
COMM_BAUD=9600
SERV_ADDR=10.0.0.5
SERV_PORT_SSL=8441
SERV_PORT_TCP=8442
SERV_PORT_2WAY=8443
LSTN_PORT=8442
SRVR_CERT="$SCRIPTPATH/certs/server.crt"
The Sketch look like this: The sketch (used the sketchbuilder) look like this:
#include <DHT.h>
char auth[] = "myauthtoken";
#define DHTPIN 2          // What digital pin we're connected to
//#define DHTTYPE DHT11     // DHT 11
#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    SwSerial.println("Failed to read from DHT sensor!");
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  dht.begin();
