I’m trying to do an aquatic cooler with a function that could turn on/off with a settable parameter (It’s a Numeric Input) in a web page using the Blynk Rest API, but I don’t know how I have to send de request to set the Start and the Stop.
I was going through Blynk REST Api documentation and found this API endpoint: http://blynk-cloud.com/auth_token/update/pin?property=value
I tried updating timer property http://blynk-cloud.com/TOKEN/update/V5?startTime=66600 but it gives error - Wrong request format.
• NodeMCU with WiFi
• Android version 10
• Blynk server
• Blynk Library v0.6.1
char pass[] = "YourPassword";
BLYNK_WRITE(V5)
Serial.print("Got a value: ");
Serial.println(param.asStr());
Thanks,
Gonzalo
