Hi !
I’ve make teperature monitoring with 3 esp8266 and DHT11. All is working exept update. I need to up temerature for updating on blynk app.
I’m using local server on Pi 0.
- Pi 0 is not adapted for local server ?
- Time interval is to little ? ( 250 ms )
- Something else ?
My sketch :
#include <DHT.h>
char auth[] = "xx";
char ssid[] = "wifi";
char pass[] = "xx";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V14, h);
Blynk.virtualWrite(V15, t);
Blynk.begin(auth, ssid, pass, IPAddress(xx), 8080);
dht.begin();
timer.setInterval(250L, sendSensor);
