Hi!
I’m creating a project using bridge that have two nodes. Node A reads temperature and humidity and the nodeB turns on/off a relay based on the humidity readed by nodeA.
In nodeA i got this code to read and change change the state of relay in nodeB:
BLYNK_WRITE(V5) {
int value = param.asInt();
autoHumidifier = value;
void getBME() {
if (enableBME) {
float t = bme.readTemperature();
float h = bme.readHumidity();
float p = bme.readPressure() / 100.0F; // hPa
float alt = bme.readAltitude(SEALEVELPRESSURE_HPA); // m
changeColor(bme.readTemperature());
// ADD A CHECK OF THE VALUES TO AVOID DATA CORRUPTION
if (t > lastT + threshold || t < lastT - threshold) {
// the reading is outside the admited limits, so, asume the value hasn't changed since last time.
t = lastT;
lastT = t;
if (h > lastH + threshold || h < lastH - threshold) {
h = lastH;
lastH = h;
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
//Blynk.notify("Failed to read sensor");
//Serial.println("Failed to read sensor");
return;
Serial.print("t");
Serial.println(t);
Serial.print("h");
Serial.println(h);
Blynk.virtualWrite(V8, bme.readHumidity());
Blynk.virtualWrite(V9, bme.readHumidity());
Blynk.virtualWrite(V10, bme.readTemperature());
Blynk.virtualWrite(V11, bme.readTemperature());
if(bme.readHumidity() < 45 && autoHumidifier == 1){
bridge1.digitalWrite(12,HIGH);
}else if(bme.readHumidity() > 55 && autoHumidifier == 1){
bridge1.digitalWrite(12,LOW);
DHTnextSampleTime = millis() + sampleInterval;
BLYNK_CONNECTED() {
bridge1.setAuthToken("*******"); // Token of the hardware B
And in the node B, I have this code:
BLYNK_WRITE(V1) {
digitalWrite(12, value);
I want to change the state of button in nodeB based on the bridged action by nodeA. In the documentation it’s said that:
Keep in mind that bridge.virtualWrite doesn’t send any value to mobile app. You need to call Blynk.virtualWrite for that.
But I’m not sure how I need to do that. Thanks!
