UPDATE All on , all off with blynk and physical button
What am i trying:
control all the lights in my house with physical buttons and the blynk app.
what is already ok:
I can control 2 lights with physical buttons and blynk. And the physical button state is synced in blynk.
what isnt ok:
i want to switch off/on all my lights at once with a physical button and with blynk.
(easy when you leave the house to switch all the lights off)
this my code to switch 2 lights whit physical buttons and blynk.
Can anybody help on how i incoporate the all on/off function?
#include <Ethernet.h>
char auth[] = "xxx";
// Set your LED and physical button pins here
const int ledPin8 = 8;
const int btnPin20 = 20;
const int ledPin9 = 9;
const int btnPin21 = 21;
void checkPhysicalButton20();
void checkPhysicalButton21();
int ledState8 = LOW;
int btnState20 = HIGH;
int ledState9 = LOW;
int btnState21 = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V2);
   Blynk.syncVirtual(V3);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
  ledState8 = param.asInt();
  digitalWrite(ledPin8, ledState8);
BLYNK_WRITE(V3) {
  ledState9 = param.asInt();
  digitalWrite(ledPin9, ledState9);
  if (digitalRead(btnPin20) == LOW) {
    if (btnState20 != LOW) {
      // Toggle LED state
      ledState8 = !ledState8;
      // Update Button Widget
      Blynk.virtualWrite(V2, ledState8);
    btnState20 = LOW;
    btnState20 = HIGH;
  if (digitalRead(btnPin21) == LOW) {
    if (btnState21 != LOW) {
      // Toggle LED state
      ledState9 = !ledState9;
      Blynk.virtualWrite(V3, ledState9);
    btnState21 = LOW;
    btnState21 = HIGH;
  Blynk.begin(auth);
  pinMode(ledPin8, OUTPUT);
  pinMode(btnPin20, INPUT_PULLUP);
   pinMode(ledPin9, OUTPUT);
  pinMode(btnPin21, INPUT_PULLUP);
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton20);
    timer.setInterval(100L, checkPhysicalButton21);
FORMAT YOUR CODE
```cpp
CODE
ok. I figured out how to switch all the leds off with a physical button.
what can I do now:
switch the leds one at a time one/off in blynk
switch the leds one at a time one/off with a physical button
switch off all the leds at once with a physical button
the state of leds sync in blynk
problem:
If i switch off all the leds at once with a physical button, and I want to switch them back on with a physical button, then I have to push the physical buttons twice.
If i switch off all the leds at once with a physical button, and I want to switch them back on in blynk, then I have to push the physical buttons only once.
anybody got an idea why this is?
const int btnPin20 = 20;    // button to toggle ledpin8
const int btnPin21 = 21;    // button to toggle ledpin9
const int btnPin19 = 19;    // button to switch ALL ledpins off
void checkPhysicalButton19();
int btnState19 = HIGH;
BLYNK_CONNECTED() {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
      // Toggle LED state
    btnState20 = LOW;
    btnState20 = HIGH;
      // Toggle LED state
    btnState21 = LOW;
    btnState21 = HIGH;
  void checkPhysicalButton19()    // button to switch ALL leds off
  if (digitalRead(btnPin19) == LOW) {
    if (btnState19 != LOW) {
      digitalWrite(ledPin9, LOW);
      digitalWrite(ledPin8, LOW);
      Blynk.virtualWrite(V3, ledPin9);
      Blynk.virtualWrite(V2, ledPin8);
  Blynk.begin(auth);
  pinMode(btnPin19, INPUT_PULLUP);
  timer.setInterval(100L, checkPhysicalButton19);
ok, i found it is because the ledState8 and ledState9 dont get set to LOW when I push button 19
I tried adding digitalWrite(ledState9, LOW), but that didnt do anything
      digitalWrite(ledState8, LOW);
     digitalWrite(ledState9, LOW);
