I am using this board
https://robotdyn.com/uno-wifi-r3-atmega328p-esp8266-32mb-flash-usb-ttl-ch340g-micro-usb.html
I have upload the code and I also connected to the wifi. I am facing some difficulty. Only one relay is continuously on and off. I have also access the arudion from the mobile. But on and off is not working. I am new in this. I have successfully connected with the wifi router
indent preformatted text by 4 spaces
const char* ssid = “Home Cable”;
const char* password = “Core44987”;
WiFiServer server(80);
pinMode(5, OUTPUT); // set the LED pin mode
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
int value = 0;
void loop(){
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println(“New Client.”); // print a message out the serial port
String currentLine = “”; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client’s connected
if (client.available()) { // if there’s bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write©; // print it out the serial monitor
if (c == ‘\n’) { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("Click <a href=\"/L\">here</a> to turn KITCHEN on.<br>");
client.print("Click <a href=\"/H\">here</a> to turn KITCHEN off.<br>");
client.print("Click <a href=\"/I\">here</a> to turn WALKWAY on.<br>");
client.print("Click <a href=\"/J\">here</a> to turn WALKWAY off.<br>");
client.print("Click <a href=\"/O\">here</a> to turn BACK DOOR on.<br>");
client.print("Click <a href=\"/P\">here</a> to turn BACK DOOR off.<br>");
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
break;
} else { // if you got a newline, then clear currentLine:
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /H")) {
digitalWrite(5, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /L")) {
digitalWrite(5, LOW); // GET /L turns the LED off
if (currentLine.endsWith("GET /I")) {
digitalWrite(12, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /J")) {
digitalWrite(12, LOW); // GET /L turns the LED off
if (currentLine.endsWith("GET /O")) {
digitalWrite(13, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /P")) {
digitalWrite(13, LOW); // GET /L turns the LED off
// close the connection:
client.stop();
Serial.println("Client Disconnected.");
