UNO + ENC28J60 + DS18B20 "Sketch too big"
I would like to make sketch: room temperature(s) to Blynk with ENC28J60 and DS18B20. When i use temperature float values, the sketch is too big. INT temperature is okay, but i would like to use decimal values for temperture(s).
Please look the sketch:
define BLYNK_PRINT Serial // Comment this out to disable prints and save space
include UIPEthernet.h>
include BlynkSimpleUIPEthernet.h>
include OneWire.h>
include DallasTemperature.h>
char auth[] = “11da2c8d999448709fc49b42b47bec0e”;
int DS18S20_Pin = 2; //DS18B20 -> D2
OneWire ds(DS18S20_Pin);
float temperature;
//DallasTemperature sensors(&ds);
//DeviceAddress Probe01 = { 0x28, 0x72, 0xCF, 0x29, 0x05, 0x00, 0x00, 0x73 };
//Serial.begin(9600); // See the connection status in Serial Monitor
Blynk.begin(auth);
// sensors.begin();
// sensors.setResolution(Probe01, 9);
// Setup function to be called each 5000 milliseconds
//timer.setInterval(5000, sendUptime);
// This function sends Arduino’s up time every second to 0rtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void sendUptime()
float temperature = getTemp();
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(0, temperature); // Virtual 0
delay(5000);
int temperature =getTemp(); //float is too big for sketch :frowning:
// timer.run(); // Initiates SimpleTimer
float getTemp(){
//returns the temperature from one DS18B20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return 100; //+100C
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println(“CRC is not valid!”);
return 100; //+100C
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print(“Device is not recognized”);
return 100; //+100C
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two’s compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
Any advice how to make sketch smaller ? I would like to use up to 8 pcs DS18B20 senors with decimal values. IS it possible for arduino uno ?
Regards,
Jonkka
You possibly forgot to comment-out the first line: “#define BLYNK_PRINT Serial”. This helped me with your sketch :smile:
Furthermore, you can comment-out line “#define BLYNK_BUILTIN” in Blynk/BlynkConfig.h to remove built-in analog and digital operations (leaves you with virtual pins only).
Remember that ENC28J60 need software implementation of TCP stack on Arduino, this is quite big.
Same for OneWire, so you get a big binary.
I would recommend looking at ESP8266 as a standalone solution…
Thanks a lot for help! :slight_smile: Now it works with one DS18B20 sensor and also decimals.
When i power boot my Arduino UNO, it will works about 1 minute. Then Blynk (android mobile app) tells than arduino uno not connected, and no temperature value anymore.
Router is working all time, maybe is it some blynk timeout ? Or router settings ?
Regards,
Jonkka
Can’t tell. You need to run Blynk with prints to understand what’s going on… (but it doesn’t fit)
