Is there a way to identify different nodemcu devices.
Suppose i have many nodemcu devices, how to i uniquely identify each of them?
With a label maker or marker pen?
But seriously, there can be many ways via code, and of course with Blynk, each will have a unique Auth token.
Basicly you need to explain the context in which you need them identified.
can you tellme any other ways via code other than with the auth token?
Again, totally depends on the context of the situation.
A visual way would be to have a simple flash code for an LED
@suhanichandrag Google has the answer to all your general ESP questions but here’s some code for you to study:
/* MACaddress.ino for https://community.blynk.cc/t/unique-identification-of-a-nodemcu/15915/3
MAC 5c:cf:7f:d0:92:83 https://www.vultr.com/tools/mac-converter/?mac_address=5c%3Acf%3A7f%3Ad0%3A92%3A83
is decimal 102046272361091 decimal blocks 92 207 127 208 146 131
MACdecimal = MAC_array[0] * pow(256,5); = 101155069755392
MACdecimal = MACdecimal + MAC_array[1] * pow(256,4); = 889058230272 total 102044127985664
MACdecimal = MACdecimal + MAC_array[2] * pow(256,3); = 2130706432 total 102046258692096
MACdecimal = MACdecimal + MAC_array[3] * pow(256,2); = 13631488 total 102046272323584
MACdecimal = MACdecimal + MAC_array[4] * pow(256,1); = 37376 total 102046272360960
MACdecimal = MACdecimal + MAC_array[5]; = 131 total 102046272361091
uint8_t MAC_array[6];
char MAC_char[18];
unsigned long long MACdecimal;
Serial.println("\n");
Serial.print("ESP MAC in decimal blocks: ");
WiFi.macAddress(MAC_array);
for (int i = 0; i < sizeof(MAC_array); ++i){
Serial.print(MAC_array[i]);
Serial.print(" ");
Serial.println();
Serial.print("ESP MAC is: ");
MACdecimal = MACdecimal + MAC_array[i] * pow(256,(5 - i));
if(i < sizeof(MAC_array) - 1)
sprintf(MAC_char,"%s%02x:",MAC_char,MAC_array[i]);
sprintf(MAC_char,"%s%02x",MAC_char,MAC_array[i]);
Serial.println(MAC_char);
/* obtain your decimal MAC from https://www.vultr.com/tools/mac-converter
and enter the EUI-48 integer value in the if statement below */
if(MACdecimal == 102046272361091L) // test by changing the last 91L to 92L
Serial.println("MAC matches");
else{
Serial.println("MAC does not match");
Serial Monitor
ESP MAC in decimal blocks: 92 207 127 208 146 131
ESP MAC is: 5c:cf:7f:d0:92:83
MAC matches
Thankyou! It helps
