Unable to upload sketch to Intel Galileo, even on library v0.3.0
Continue to get this error message every time I try to upload the Blynk Ethernet sketch.
Error message:
WARNING: library Ethernet claims to run on [i586-uclibc] architecture(s) and may be incompatible with your current board which runs on [i586] architecture(s).
Ethernet example is for Ethernet shield. Intel is Intel :wink:
Check this links:
https://github.com/blynkkk/blynk-library/tree/master/examples/BoardsAndShields
So, which sketch should I use for ethernet on Intel galileo?
@vshymanskyy would be the best person to answer.
First of all, Galileo is not tested yet.
I recommend you to try our Node.js library instead of Arduino…
Ok, thanks, I will try that
