BLYNK
Unable to receive data from virtual pin, showing %3f
#1
I am a new user of blynk.
I have make a simple project to read Temperature and humidity.
The code is Ok, as I can read the value in the monitor.
But in the app on my smartphone, I never receive the value.
The connection is good.
I have put a switch to test with the led, and it’s OK
I have 2 virtuals pin (5 & 6)
I use 2 labeled Value
Select the correct virtual pin for each
put the value “Temp: /pin/ °C” and “Humid: /pin/ °C”
And Push mode.
If I start, I can read Temp: %3f °C and Humid: %3f °C
What is wrong?
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how value can be pushed from Arduino to
  the Blynk App.
  WARNING :
  For this example you'll need Adafruit DHT sensor libraries:
    https://github.com/adafruit/Adafruit_Sensor
    https://github.com/adafruit/DHT-sensor-library
  App project setup:
    Value Display widget attached to V5
    Value Display widget attached to V6
#include <DHT.h>
char auth[] = "3c873a1092d44f068b34ab33e02f4363";
char ssid[] = "virus.exe";
char pass[] = "olivierlegros";
#define DHTPIN 5          // What digital pin we're connected to
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  else {
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print(t);
    Serial.println(" *C ");
  Blynk.virtualWrite(V5,h);
  Blynk.virtualWrite(V6,t);
  dht.begin();
Thanks for your help
#2
Did you look for “%3f” at this forum?
#3
I have the exact same problem…
#4
Searching this forum would have shown that recent changes require the latest ESP Arduino core 2.4.1
closed #5
