Oh sir, I have renamed my bt module to helios before that it responded with hc05!!
And I have used them with mit appinventor they work well!
It’s only with blynk I’m not able to!!
INFACT NOT EVEN CONNECTING TO IT!
ALSO I HAVE CHANGED THE BAUD RATE TO 9600!!
Through AT command mode!
My advice would be to reset the HC-05 to its factory settings and try a connection using the default baud rate of 38400.
What does your serial monitor show when using the GitHub code?
Ya sure sir!
And horribly nothing displays on my serial monitor!
But the code that the example generator gave (yes after fixing it)there was a serial monitor display that says…
Connecting…
Time out…
Forever!
In that case, you’re doing something wrong. It should print “Waiting for connections…” at the very least.
Oh… Ya just like for the nodemcu right??
So is there any correct code that I can try??
Plzz direct me to that!!
Stop searching for different code and try to figure out why you aren’t getting any serial monitor output.
Fine will do that soon!
Hey Pete sir, thanks a lot I got it working, but sometimes there will be connection fluctuating but I guess I can fix that by adding some cap or other passive components to the bt!
Thanks a lot sir!
What was the final one thing you changed to make it work?
It was probably the main problem all along.
