Unable to connect bluetooth to Arduino Uno + nrf8001
Hi Everyone!!
I’m attempting to connect Blynk to my Arduino Uno with Adafruit nRF8001 breakout board
The code below is the standard nRF8001 code in the blynk examples
Code compiles and uploads to the board although when i try and find the device using the Bluetooth widget in the Blynk app it fails to recognise a device
Ive succesfully attempted to connect to the arduino using the default Adafruit example and Adafruit app
Any help would be very much appreciated
Many thanks
• Hardware model + communication type: Arduino UNO with nRF8001
• Smartphone IOS
• Blynk Library version : V0.5.2
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  For this example you need BLEPeripheral library
    from http://librarymanager/all#BLEPeripheral
    or https://github.com/sandeepmistry/arduino-BLEPeripheral
  Warning: Bluetooth support is in beta!
#include <BlynkSimpleBLEPeripheral.h>
#include <BLEPeripheral.h>
char auth[] = "f530fa8d479247f995e6d3d98f8a610e";
// define pins (varies per shield/board)
#define BLE_REQ   10
#define BLE_RDY   2
#define BLE_RST   9
// create ble serial instance, see pinouts above
BLESerial SerialBLE(BLE_REQ, BLE_RDY, BLE_RST);
  SerialBLE.setLocalName("Blynk");
  SerialBLE.setDeviceName("Blynk");
  SerialBLE.setAppearance(0x0080);
  SerialBLE.begin();
  Blynk.begin(SerialBLE, auth);
  SerialBLE.poll();
  if (SerialBLE) {    // If BLE is connected...
Another thing,
If i use the code from the online Blynk example builder, i get the following error:
no matching function for call to 'BLESerial::BLESerial(int, int, int)'
Code Below:
    Follow us:                  http://www.fb.com/blynkapp
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - Arduino Uno board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
#include "BLESerial.h"
#define BLE_REQ   10
#define BLE_RDY   2
#define BLE_RST   9
  SerialBLE.begin();
  SerialBLE.poll();
  // to avoid delay() function!
