Ultrasonic sensor + wemos D1 + blynk
hello Every one :slight_smile:
need help with my iot project counting people coming into room using ultrasonic sensor and using wemos D1
,using blynk having problem with the output at blynk
i have write code
#include <Wire.h>  // Comes with Arduino IDE
#define echoPin D6 // Echo Pin (wemos D1)
#define trigPin D7 // Trigger Pin(wemos D1)
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxx";
int counter = 0;
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  Blynk.begin(auth, ssid, pass );
BLYNK_wRITE(V5){
if(param.asInt())
counter++;
if(counter == 50)
 counter = 0;
long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH );
  delayMicroseconds(10);
  distance = (duration/2) / 29.1;
  Blynk.virtualWrite(V5, counter);
  delay(200);
  Blynk();
sorry for bad English
you need to clean the loop and use timer to call ultrasonic function
thank you for the tip
here the new code that me wrote
dont sure the code right or not
#include <Blynk.h>
char auth[] = “b6da92205d3c44dfa91f079ae363cf16”;
// Set password to “” for open networks.
char ssid[] = “okazaki”;
char pass[] = “zakizaini96”;
long duration, distance; // Duration used to calculate distance
int sensorCounter = 0; // counter for the number of button presses
int lastsensorDistance = 0;
int incomingByte;
timer.setInterval(1000L, sensorDataSend);
void sensorDataSend()
if (Serial.available() > 0) { // see if there’s incoming serial data:
incomingByte = Serial.read(); // read the oldest byte in the serial buffer:
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
if (distance <= 20 && lastsensorDistance >= 40){
sensorCounter++;
Blynk.virtualWrite(V1,sensorCounter);
Serial.println(sensorCounter);
else {
//Serial.println(“off”); not needed.
lastsensorDistance = distance;
delay(500);
please format your code with back tips and delete ‘delay(500);’
