two users on a local server with same Auth token
the new user is always offline is that correct ?
is the Auth token related to user name ?
Yes and you can’t edit tokens in the Admin panel without messing up your system.
thanks Costas.
but can we run the same hardware for different users .
Yes you can share the app or just log in as the same person 50 times on 50 Smartphones.
that is not what i mean
ex. two different user with diff. names sharing the same “nodeMCU”
look up sharing in the docs.
