Turn on-off relay with button[esp8266]
Hi! I’m new here. Sorry for bad English.
use esp8266 board and 5VDC relay
Problem: I want to Turn on-off relay with button in Blynk2.0 But when I try It’s nothing happen.
This is my code:
#define BLYNK_TEMPLATE_ID "TMPL1ZBP7FMf"
#define BLYNK_DEVICE_NAME "MUSHROOM"
#define BLYNK_AUTH_TOKEN "zPr0Mmvo91aC1lz2FKtccRIsz6xyfdw-"
#include <DHT.h>
#include <DHT_U.h>
char ssid[] = "Tawan_2.4G";
char pass[] = "0927015667";
#define DHTPIN D2
#define DHTTYPE DHT11
#define relay D1
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  dht.begin();
  pinMode(relay, OUTPUT);
  Serial.println(dht.readHumidity());;
BLYNK_WRITE(V1)
  int button = param.asInt();
  if (button == 1){
   digitalWrite(relay, HIGH);
  else if (button == 0){
    digitalWrite(relay, LOW);
I assume that button is connected to a datastream linked to virtual pin V1?
How is that datastream configured (Data Type and Min/Max values)?
Is your device showing as Online?
I recheck in my app I forget to select datastream.
It’s work now Thanks!
