Trying to send Slider value to second esp via bridge problem
I thought this should be relatively easy, but obviously doing something stupid!
Start with
WidgetBridge bridge1(V20);
In setup put.
bridge1.setAuthToken(“a0f47af8c4I*****eb725eee3e490be3f”);
Checked auth token in dashboard of user file in local server files for being correct for the second esp.
Then added.
BLYNK_WRITE(V20)
int slidV20val = param.asInt();
Serial.print("slider val = ");
Serial.println(slidV20val);
bridge1.virtualWrite(20,slidV20val);
I thought that should send over the slider value, but I’m not getting any response?
Have I over complicated it? Any help much appreciated.
Please post full code. Also use formatting for code.
didnt format …
#include <EEPROM.h>
#include "ESP8266WiFi.h"
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
#include<SimpleTimer.h>
#include <DHT.h>
#include <PubSubClient.h>
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
byte spiDat =0; // spi data to send
DHT dht(4, DHT11,11);
MDNSResponder mdns;
WiFiServer server(80);
//char auth[] = "47e420915db74a2a90439a60b71a7cf8"; // local server token
//char auth[] = "88b810d70d8444b080666ee1928bc955"; // Blynk token "YourAuthToken"
const char* APssid = "ESP8266"; // Name of access point
const char* servAuth;
const char* servi ;
const char* mypass;
const char* mysid;
//const char* mysid1;
String st;
String rsid;
String rpass;
String rserv;
String rkey;
String epsid;
 String eppass;
 String epserv;
 String epauth;
boolean newSSID = false;
String key;
int checkV0= 0;
WidgetLED led1(0);
WidgetLCD lcd(6);
int pos = 0;
int slidV20val;
IPAddress server_ip (0, 0, 0, 0);
  Serial.println("Startup");
   EEPROM.begin(512);
  if (digitalRead(2)==0){eepromClearSid();}
 bridge1.setAuthToken("e32670c7d9b1417ab0b10638223222bd");
  eepromRead();
  int count=0;
  SPI.begin();
  WiFi.begin(mysid,mypass);     // gets from eeprom read.
  Serial.println(" trying wifi begin");
   pinMode(5,OUTPUT);
  pinMode(2,OUTPUT);
  digitalWrite(2,HIGH);
  pinMode(16,OUTPUT);
  digitalWrite(16,HIGH);
  if ( testWifi()) {
    // string epserv in the form of xxx#xxx$xxx%xxx*
          //need to extract each number string, convert to value, and put into server_ip
          String ip_one;
          String ip_two;
          String ip_three;
          String ip_four;
           ip_one=epserv.substring(0,epserv.indexOf('#'));
           ip_two=epserv.substring(epserv.indexOf('#')+1,epserv.indexOf('$'));
           ip_three=epserv.substring(epserv.indexOf('$')+1,epserv.indexOf('%'));
           ip_four=epserv.substring(epserv.indexOf('%')+1,epserv.indexOf('*'));
          Serial.println(ip_one);
          Serial.println(ip_two);
          Serial.println(ip_three);
          Serial.println(ip_four);
          server_ip[0]= ip_one.toInt();
          server_ip[1]= ip_two.toInt();
          server_ip[2]= ip_three.toInt();
          server_ip[3]= ip_four.toInt();
           Serial.println ("Blynk begin?");
           if (server_ip[0]==1 && server_ip[1]==1 && server_ip[2]==1 && server_ip[3]==1)
           Serial.print("going Cloud");
           Blynk.config(servAuth);
           bool result = Blynk.connected();
          Serial.print(result);
          if (!result){digitalWrite(2,LOW);}
           Serial.println("going local");
           Serial.println(server_ip);
           Blynk.begin(servAuth,mysid,mypass,server_ip);
          client.setServer("192.168.1.162", 1883);
          client.setCallback(callback);
          return;
  // otherwise, set up an access point to input SSID and password
    {  Serial.println("");
      Serial.println("Connect timed out, opening AP");
      setupAP();   }
 dht.begin();
//********** end of setup
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  // Switch on the LED if an 1 was received as first character
 //*** if ((char)payload[0] == '1') {
 //***   digitalWrite(BUILTIN_LED, LOW);   // Turn the LED on (Note that LOW is the voltage level
    // but actually the LED is on; this is because
    // it is acive low on the ESP-01)
//***  } else {
//***    digitalWrite(BUILTIN_LED, HIGH);  // Turn the LED off by making the voltage HIGH
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("outTopic", "hello world");
      // ... and resubscribe
      client.subscribe("inTopic");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
int testWifi(void) {
  long Timeout = (millis() + 10000);
  Serial.print("Waiting for Wifi to connect. ");
  while (millis() < Timeout){
    delay(500);
    Serial.print(".");
    if (WiFi.status() == WL_CONNECTED) {
      Serial.println("");
      Serial.println("WiFi connected.");
      return(1);
  return(0);
void launchWeb(int webtype) {
    Serial.println("");
    Serial.println(WiFi.softAPIP());
    // Start the server
    server.begin();
    Serial.println("Server started");
    int b = 20;
    int c = 0;
    while(b == 20) {
       b = mdns1(webtype);
       //If a new SSID and Password were sent, close the AP, and connect to local WIFI
       if (newSSID == true){
          newSSID = false;
          Serial.println ("reading eeprom");
          eepromRead();
          Serial.println("Connecting to local Wifi"); //Close the AP and connect with new SSID and P/W
          WiFi.softAPdisconnect(true);
          delay(500);
          Serial.println(epsid);
          Serial.println(eppass);
          Serial.println(epauth);
          Serial.println(epserv);
          mysid = epsid.c_str();
          mypass =eppass.c_str();
          servi = epserv.c_str();
          servAuth = epauth.c_str();
          delay(3000);
          String ip_one;
          String ip_two;
          String ip_three;
          String ip_four;
          if ( testWifi()) {
           Blynk.config(servAuth);}
            return;
         else{
            Serial.println("");
            Serial.println("New SSID or Password failed. Reconnect to server, and try again.");
            setupAP();
            return;
void setupAP(void) {
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0)
    Serial.println("no networks found");
    Serial.print(n);
    Serial.println(" networks found");
  Serial.println("");
  st = "<ul>";
  for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      st += "<li>";
      st += WiFi.SSID(i);
      st += " (";
      st += WiFi.RSSI(i);
      st += ")";
      st += (WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*";
      st += "</li>";
  st += "</ul>";
  delay(100);
  WiFi.softAP(APssid);
  Serial.println("softAP");
  Serial.println("");
  launchWeb(1);
String urldecode(const char *src){ //fix encoding
  String decoded = "";
    char a, b;
  while (*src) {
    if ((*src == '%') && ((a = src[1]) && (b = src[2])) && (isxdigit(a) && isxdigit(b))) {
      if (a >= 'a')
        a -= 'a'-'A';
      if (a >= 'A')
        a -= ('A' - 10);
        a -= '0';
      if (b >= 'a')
        b -= 'a'-'A';
      if (b >= 'A')
        b -= ('A' - 10);
        b -= '0';
      decoded += char(16*a+b);
      src+=3;
    else if (*src == '+') {
      decoded += ' ';
      *src++;
    else {
      decoded += *src;
      *src++;
  decoded += '\0';
  return decoded;
int mdns1(int webtype){
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return(20);
  Serial.println("");
  Serial.println("New client");
  // Wait for data from client to become available
  while(client.connected() && !client.available()){
    delay(1);
  // Read the first line of HTTP request
  String req = client.readStringUntil('\r');
  // First line of HTTP request looks like "GET /path HTTP/1.1"
  // Retrieve the "/path" part by finding the spaces
  int addr_start = req.indexOf(' ');
  int addr_end = req.indexOf(' ', addr_start + 1);
  if (addr_start == -1 || addr_end == -1) {
    Serial.print("Invalid request: ");
    Serial.println(req);
    return(20);
  req = req.substring(addr_start + 1, addr_end);
  Serial.print("Request: ");
  client.flush();
  String s;
  if ( webtype == 1 ) {
      if (req == "/")
        IPAddress ip = WiFi.softAPIP();
        String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
        s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>";
        s += "<font face='arial,helvetica' size='7'>";
        s += "<b><label>Hello from ESP8266 at ";
        s += ipStr;
        s += "</label></b><p>";
        s += st;
        s += "<form method='get' action='a'><label>SSID: </label><input name='ssid' style='width:200px; height:60px; font-size:50px;'>   ";
        s += "<label>Password: </label><input name='pass*' style='width:200px; height:60px; font-size:50px;'>";
        s += "<p><label>Server: </label><input name='serv+' style='width:200px; height:60px; font-size:50px;'>";
        s += "<p><label>Token: </label><input name='key' style='width:300px;height:60px; font-size:50px;'>";
        s += "<p><input type='submit' style='font-size:60px'></form>";
        s += "</html>\r\n\r\n";
        Serial.println("Sending 200");
      else if ( req.startsWith("/a?ssid=") ) {
        newSSID = true;
        String qsid; //WiFi SSID
        qsid = urldecode(req.substring(8,req.indexOf('&')).c_str()); //correct coding for spaces as "+"
        Serial.println(qsid);
        Serial.println("");
        rsid = qsid;
        String qpass; //Wifi Password
        qpass = urldecode(req.substring(req.indexOf('*')+2,req.lastIndexOf('%')-5).c_str());//correct for coding spaces as "+"
        Serial.println(qpass);
        Serial.println("");
        rpass = qpass;
        String qserv; //Wifi server port
        qserv = urldecode(req.substring(req.lastIndexOf('%')+4,req.lastIndexOf('&')).c_str());//correct for coding spaces as "+"
        Serial.println(qserv);
        Serial.println("");
        rserv = qserv;
         String qkey; //Wifi auth
        qkey = urldecode(req.substring(req.lastIndexOf('=')+1).c_str());//correct for coding spaces as "+"
        Serial.println(qkey);
        Serial.println("");
        rkey = qkey;
       // conversion allocation of string to const char
       // const char* conv_my_str = my_str.c_str();
        mysid=qsid.c_str();
        mypass=qpass.c_str();
        servi=qserv.c_str();
        servAuth = qkey.c_str();
        Serial.print("at eeprom write stage");
        Serial.println ( mysid);
        Serial.println ( mypass);
        Serial.println ( servi);
        Serial.println ( servAuth);
        String allintoEP;
         allintoEP += qsid;
         allintoEP += qpass;
         allintoEP += qserv;
         allintoEP += qkey;
         char epssid[allintoEP.length()];
          allintoEP.toCharArray(epssid, allintoEP.length());
         int epcount=0;
         while (epcount < allintoEP.length()){
        if (allintoEP[epcount] == 0) {allintoEP[epcount]=42;}  // puts a "*" between variables
         EEPROM.write(epcount,allintoEP[epcount]);
          epcount ++;
         EEPROM.commit();
      //  servi= rserv.c_str();
        s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>Hello from ESP8266 ";
        s += "<p> New SSID and Password accepted</html>\r\n\r\n";
        s = "HTTP/1.1 404 Not Found\r\n\r\n";
        Serial.println("Sending 404");
      if (req == "/")
        s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>Hello from ESP8266";
        s += "<p>";
  client.print(s);
  Serial.println("Done with client");
  return(20);
void eepromClearSid(){
  byte value=0;
  int count=0;
  int len = 61;
  int addr;
  while (addr < len){
  value= 65;
  if (count ==15 || count ==30 || count == 45 || count == 60){ value=42;}
  EEPROM.write(addr,value);
  addr++;
  count++;
  EEPROM.commit();
void eepromRead() {
 epsid="";
 eppass="";
 epserv="";
 epauth="";
 String llit;
 int len = 200;
 int addr=0;
 int count=0;
 byte value;
 byte marker=35; // "#"
 while (count < len) {
 value= EEPROM.read(addr);
 if (value != 42){
 epsid += char(value);}
 count++;
 addr++;
 if (value == 42){ break; }
Serial.print("epsid =");
 if (value != 42){
 eppass += char (value);}
 count++;
 addr++;
 Serial.print("eppass =");
 //epserv = char(34);  //"
 if (value != 42){                  //  *
 if (value == 46){ value = marker;marker++;}     //46 = .  marker starts with # then $ then %
 epserv += char(value);}
  count++;
 addr++;
  epserv += char(42);   //*
 Serial.print("epserv =");
 if (value != 42){
 epauth += char(value);}
  count++;
 addr++;
Serial.print("epauth =");
// mysid= fill.c_str(); assign string to const char
Serial.print("mysid=");
Serial.println(mysid);
Serial.print("mypass=");
Serial.println(mypass);
Serial.print("servi=");
Serial.println(servi);
Serial.print("servAuth=");
Serial.println(servAuth);
BLYNK_WRITE(V30){
// hopefully will read slider 3;
String pinData = param.asStr();  // data comingin
slidV20val = param.asInt()/4;
const char* slid_dat =  pinData.c_str();
client.publish("outTopic", slid_dat);
 SPI.beginTransaction(SPISettings(1000000,MSBFIRST,SPI_MODE0));
  byte spidata = slidV20val; //133;
  Serial.print(spidata);
  byte spiback;
  int numdata=0;
  digitalWrite(16,LOW); //chip select low
  SPI.transfer(0);
  SPI.transfer(spidata);
  Serial.print("");
  SPI.transfer(1);
  SPI.endTransaction();
  digitalWrite(16,HIGH); //chip cs high and transfer data
BLYNK_WRITE(V0)
 spiDat=1;
 spiSEND();
BLYNK_WRITE(V1)
 spiDat=2;
 spiSEND();
BLYNK_WRITE(V2)
 spiDat=3;
 spiSEND();
BLYNK_WRITE(V3)
 spiDat=4;
 spiSEND();
BLYNK_WRITE(V4)
 spiDat=5;
 spiSEND();
BLYNK_WRITE(V5)
 spiDat=6;
 spiSEND();
BLYNK_WRITE(V6)
 spiDat=7;
 spiSEND();
BLYNK_WRITE(V7)
 spiDat=8;
 spiSEND();
BLYNK_WRITE(V8)
 spiDat=9;
 spiSEND();
BLYNK_WRITE(V9)
 spiDat=10;
 spiSEND();
BLYNK_WRITE(V10)
 spiDat=11;
 spiSEND();
BLYNK_WRITE(V11)
  spiDat=12;
  spiSEND();
BLYNK_WRITE(V12)
 spiDat=13;
 spiSEND();
BLYNK_WRITE(V13)
 spiDat=2;
 spiSEND();
BLYNK_WRITE(V20)
 void spiSEND(){
  Serial.print(" spiDat = ");
  Serial.println(spiDat);
 // SPI.transfer(123 );
  SPI.transfer(spiDat);
  yield();
// if (server_ip[0]!=1 && server_ip[1]!=1 && server_ip[2]!=1 && server_ip[3]!=1)
// if (!client.connected()) {
 //   reconnect();
//  client.loop();
This is driving me f nuts.
Ok , in the documents using bridge …
WidgetBridge bridge1(1); //Bridge widget on virtual pin 1
In the sketch …
WidgetBridge bridge1(V1);
Tried both, but what should it be!
It all looks pretty simple , set up the WidgetBridge bridge1( virtual pin).
wait till the connection is made … which I do. Then set the bridge auth code to the device you want the data to go to, as if from its own project…
if (!result){
bridge1.setAuthToken(“22a7baf858dd4e22a639c4bff166360e”);
Then in the rest of the code …
BLYNK_WRITE(V30)
  bridge1.virtualWrite(20, slidV20val);
So, I would expect the received data to also be sent to the esp pointed to by its auth code.
The second esp has a BLYNK_WRITE(V20) which sends out spi data. It does if I write to using it’s project.
But why not from a bridge sending project?
My understanding of bridge …
Assign a virtual pin via WidgetBridge to the transport mechanism.
When a connection to the server is made, tell it via bridgeX.setAuthToken to send data to this other device attached to the server when instructed.
In the ‘sketch’ transmit data via the bridge mechanism to a device referred to by the bridge authtoken.
Am I missing something?
All sorted now thanks … All the thought processes correct … software principles correct … there’s a difference between instructions relating to how the perception of what is considered a connection to the server is though!
Could have had a very simple answer to this days ago.
Btw, this is just an alias to 1.
It’s created for better code readability.
Thanks for the reply … in fact my bridge setup works with V20 etc typed into Widget and bridge virtualWrite, so I got lucky there!
My issue was that of the timing of the setAuthToken. Using Blynk.connected() did not work whilst ’ while (Blynk.connect() == false) ’ wait loop before setAuth did.
A lesson for me.
