I need help with my project.
Any help appreciated!
#include <TinyGPS++.h>
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "********";
char ssid[] = "********";
char pass[] = "********";
WidgetMap myMap(V0);
TinyGPSPlus gps;
// If you want to remove all points:
//myMap.clear();
int index = 1;
float lat = 51.5074;
float lon = 0.1278;
myMap.location(index, lat, lon, "value");
timer.setInterval(2000L, myTimerEvent4); //2sec timer
void myTimerEvent4() {
// This sketch displays information every time a new sentence is correctly encoded.
while (Serial1.available() > 0)
if (gps.encode(Serial1.read()))
displayInfo();
void displayInfo() {
if (gps.location.isValid()) {
lat = gps.location.lat(); //get latitude and longitude
lon = gps.location.lng();
Blynk.virtualWrite(V12, 1, lat, lon, "car"); //write to Blynk map
//create location string which can be used directly in Google maps
slocation = String(lat) + "," + String(lon);
spd = gps.speed.kmph(); //get speed
Blynk.virtualWrite(V13, spd);
bearing = TinyGPSPlus::cardinal(gps.course.value()); //direction
Blynk.virtualWrite(V14, bearing);
sats = gps.satellites.value(); //get number of satellites
Blynk.virtualWrite(V15, sats);
hdop = gps.hdop.value() / 10; //get accuracy of location
Blynk.virtualWrite(V16, hdop);
msg5 = "GPS Good";
Blynk.virtualWrite(V11, msg5);
msg5 = "Invalid Data";
ERROR MESSAGE:
Arduino: 1.8.14 Hourly Build 2020/09/14 03:35 (Mac OS X), Board: âArduino MKR WiFi 1010â
sketch/GPS_BLYNK_Yannis.ino.cpp:2:63: warning: trigraph ??/ ignored, use -trigraphs to enable [-Wtrigraphs]
#line 1 â/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.inoâ
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:18:64: warning: trigraph ??/ ignored, use -trigraphs to enable [-Wtrigraphs]
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:19:64: warning: trigraph ??/ ignored, use -trigraphs to enable [-Wtrigraphs]
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:38:64: warning: trigraph ??/ ignored, use -trigraphs to enable [-Wtrigraphs]
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:47:64: warning: trigraph ??/ ignored, use -trigraphs to enable [-Wtrigraphs]
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:72:64: warning: trigraph ??/ ignored, use -trigraphs to enable [-Wtrigraphs]
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino: In function âvoid displayInfo()â:
GPS_BLYNK_Yannis:48:8: error: âlatâ was not declared in this scope
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:48:8: note: suggested alternative: âUartâ
Uart
GPS_BLYNK_Yannis:49:8: error: âlonâ was not declared in this scope
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:49:8: note: suggested alternative: âlogâ
log
GPS_BLYNK_Yannis:52:8: error: âslocationâ was not declared in this scope
slocation = String(lat) + â,â + String(lon);
GPS_BLYNK_Yannis:53:8: error: âspdâ was not declared in this scope
GPS_BLYNK_Yannis:55:8: error: âbearingâ was not declared in this scope
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:55:8: note: suggested alternative: âStringâ
String
GPS_BLYNK_Yannis:57:8: error: âsatsâ was not declared in this scope
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:57:8: note: suggested alternative: âpassâ
pass
GPS_BLYNK_Yannis:59:8: error: âhdopâ was not declared in this scope
/Users/yannis/Documents/Arduino/sketch_GPS_WORKING_???/GPS_BLYNK_Yannis/GPS_BLYNK_Yannis.ino:59:8: note: suggested alternative: âloopâ
loop
GPS_BLYNK_Yannis:61:8: error: âmsg5â was not declared in this scope
msg5 = âGPS Goodâ;
GPS_BLYNK_Yannis:66:8: error: âmsg5â was not declared in this scope
msg5 = âInvalid Dataâ;
exit status 1
âShow verbose output during compilationâ
