Hello all
So, I am trying to create a project with a sketch on the ESP8266 and the Blynk app on my iPhone that simply turns an LED on pin 7 of the NodeMCU ESP8266 board On and OFF.
From the examples.Blynk.cc page, I selected I have selected the
Board: NodeMCU
Connection: ESP8266 WiFi
Example: Blynk Blink
I have amended the code to reflect my SSID and password, and I have added the Auth token. So far so good!
Next, building the Blynk project on my iPhone. I created a new project, and added a button, assigned it to digital pin 7.
I have built the circuit with and LED across Pin7 and Gnd.
I have uploaded the sketch.
Now the issue - nothing happens. I see ‘iPhone LED’ (the name I gave my project) is offline.
What am I doing wrong please?
Hello.
Well, that’s it. Your NodeMCU is not connected. Try to open serial output. What is shows?
Hi Dimitri
I tested the connection using another piece of code, and it connects correctly. I even built a sketch and used some embedded HTML to create buttons for ON and OFF - and that worked fine, both on a web page on my Mac and on the iPhone in Safari.
I will keep trying… maybe it takes a few seconds to connect to my hotspot, so perhaps I should incorporate some loop until it is connected showing the connection status in Serial Monitor.
While you are here - is there a command to return connection status?
I’ll update here if I get it working, thanks so much for replying, much appreciated.
John
There is a chance your router blocks ports Blynk work with. You may want to check - http://docs.blynk.cc/#troubleshooting and detailed - http://help.blynk.cc/hardware-and-libraries/esp8266/nodemcu instruction for getting started.
Just managed to get it working, Dimitri! I use an iPhone hotspot for my home WiFi, once I stopped that and restarted it, Blynk connected and it all works.
