Trying to connect esp8266 to bme280 but cant pull out readings
Hi, Iā€™m trying to connect an Adafruit Huzzah ESP8266 to a BME280 sensor, but i cant seem to pull any values out, I think Iā€™m having trouble with the SPI connection?
This is my code, I used a similar setup with a 101 and it worked fine.
Any ideas?
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK 14
#define BME_MISO 12
#define BME_MOSI 13
#define BME_CS 15
#define SEALEVELPRESSURE_HPA (1011)
//connect #0,#15 -> low 220 ohm R, take #2 high - cycle
//HSPI 12-MISO, 13-MOSI, 14-CLOCK, 15-CS (16)
char auth[] = "xxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxxxx";
//Adafruit_BME280 bme(BME_CS);
Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO,  BME_SCK);
void sendSensor()
  Wire.begin(); //just added
  float t = bme.readTemperature();
  float p  = (bme.readPressure() / 100.0F);
  float h =  bme.readHumidity();
  float a =  bme.readAltitude(SEALEVELPRESSURE_HPA);
  if (isnan(t) || isnan(p) || isnan(h) || isnan(a)) {
    Serial.println("Failed to read from BME sensor!");
    return;
  Blynk.virtualWrite(V0, t);
  Blynk.virtualWrite(V1, p);
  Blynk.virtualWrite(V2, h);
  Blynk.virtualWrite(V3, a);
  while (Blynk.connect() == false)
    bme.begin();
To start with you have included the SPI library twice.
Have you also had any success with the example provides in the BME280 library?
Yes i got that example to work in the serial monitor and then amended another for the DHT22 for BLE
Add this code to your setup:
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
Thanks seems to be working great now :thumbsup:
actually it only appears to be working with the FTDI friend connected
EDIT: just my spark fun power supply not giving its labeled power outage
