Hi @BlynkAndroidDev, both logs on your wayā¦ one selecting my local server, the other one to cloud server.
Let me know if you need something else
Regards
Iām uploading a new version with some crash fixes and app name fix, but I donāt think it will fix your ānot registeredā error. It looks like both servers return this exact error, and it is not a bug on apps side with the wrong message or smth else.
Does this user exist on your local server? Have you tried to reset password, for example - does the server sends āPassword restorationā email?
I suppose it is a result of this appās name bug with the library (as it sends app name as app identifier to the server) - it should be fixed with the new version. It should be available quite soon.
Yes, it does! Same user for local and cloud accounts
When I click on āForgot passwordā, my email is shown and click on āsendā a message appears saying āSomething went wrong. Please try again laterā
Yep, got it, as I wrote above - I suppose it is a result of the video library name override bug. Next build should fix this issue.
Cool!!
Leaving Beta tester till new updateā¦
Thanks for your support!
Updated to 2.28.10ā¦
ā¦And GiraffePlayer is still here and the same behaviour
Logs sent
Regards
Can you check is there an update for you, there have been two 2.28.10 versions - the last one should fix the login issue. Iām investigating why did the app name has not been fixed on your side. I will later try another fix and upload a build.
Just pushed 2.28.11 so there will be no confusion about several 2.28.10 updates.
