Trouble with connecting Blynk to nodeMCU. please help fast
I have recently started using blynk.I am trying to connect my nodeMCU board to blynk .the code is uploading just fine but when i go to blynk app the board is shown as offline.please help as i need to complete this project in a 5 days.
It was working at first but i think i messed up a few libraries.its just a guess
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on NodeMCU.
  Please be sure to select the right NodeMCU module
  in the Tools -> Board menu!
  For advanced settings please follow ESP examples :
   - ESP8266_Standalone_Manual_IP.ino
   - ESP8266_Standalone_SmartConfig.ino
   - ESP8266_Standalone_SSL.ino
char auth[] = "*************************";
char ssid[] = "Gill";
char pass[] = "*************";
You created two topics about the same problem.
I’ve merged them in to one - please don’t do that again.
If you want help with this issue then you need to provide more information, especially details about what you see in your serial monitor.
The serial monitor wasnt showing anything.i read something about pinging blynk.could somebody tell me about that.or do i set up a local server
You don’t need to ping the Blynk cloud server for what you are doing, and setting-up a Blynk local server is most likely too complex for you - and totally unnecessary.
You need to figure-out why your serial monitor isn’t working, as that will give you lots of useful information.
thanks a lot
