Trouble getting output for my turbidity sensor./using wemos d1 mini
CONNECTED)
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Connect to Blynk
  Serial.println("Blynk connected");
  // Read the analog value from the sensor
  int sensorValue = analogRead(sensorPin);
  Serial.println(sensorValue);
  // Send the value to Blynk
  Blynk.virtualWrite(V0, sensorValue);
  // Wait a little before reading the sensor again
16:48:55.092 -> WiFi connected
only that shows on my serial mon
First of all, you should read this
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
also, you should add
To the void loop.
Posting snippets of code serves no purpose.
Post your full sketch, and replace any sensitive information such as Auth token and SSID/password with the word “REDACTED”.
Incomplet code
