Hello everybody,
I’m trying to automate my swing gates in which I need a sequence to be as follows:
for opening both halves there must be a pause between powering the left and right motors
closing is done in reverse order
I did this for arduino but arduino’s interrupt goes crazy near AC magnetic interference
int setdelay = 500;
int setdelay1 = 10;
int counter1 = 0;
static unsigned long last_interrupt_time1 = 0;
volatile int counter = 0;
int LampState = HIGH;
const int lampPin = 1;
const int leftopenPin = 7;
const int leftclosePin=6;
const int rightopenPin = 4;
const int rightclosePin = 5;
unsigned long TimerA;
unsigned long PreviousTimer = 0;
char auth[] = "";
char SSID[] = "Linksys";
char pass[] = "3";
BLYNK_WRITE(V1)
int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
counter == counter + pinValue;
BLYNK_WRITE(V2)
int setdelay1 = param.asInt(); // assigning incoming value from pin V1 to a variable
Blynk.begin(auth, SSID, pass, IPAddress(192, 168, 2, 199));
while ((counter == 1) || (counter == 3)) {
TimerA = millis();
if (TimerA - PreviousTimer > setdelay) {
PreviousTimer = TimerA;
if (LampState == LOW) {
LampState = HIGH;
LampState = LOW;
digitalWrite(lampPin, LampState);
counter1++;
if (counter1 > setdelay1) {
counter1 = 0;
//digitalWrite lampPin, HIGH);
switch (counter) {
case 0:
digitalWrite (leftopenPin, HIGH);
digitalWrite(rightopenPin, HIGH);
digitalWrite (leftclosePin, HIGH);
digitalWrite(rightclosePin, HIGH);
break;
case 1:
digitalWrite (leftopenPin, LOW);
if (counter1 > 8) {
digitalWrite(rightopenPin, LOW);
if (counter1 >= setdelay1) {
counter++;
break;
case 3:
digitalWrite (rightclosePin, LOW);
if (counter1 > 8) {
digitalWrite(leftclosePin, LOW);
counter++;
break;
Sure, I’ve seen some funny pics like this. I will not use my gate while using TXD or RXD and vice versa.
What bothers me most is the fact that GPIO 4 and 5 are silent which are D1 and D2 in NODEMCU. .
Blynk’s Simple Timer runs all the, Jamin. I need something that allow triggering certain relays in a sequence: one relay ON- pause 2 sec (relay still on) - second relay ON - all 2 relays off after 15 seconds from first action.
Other ideas are welcome.
void actionRelays(){
relay1_ON(); // turn on relay1
timer.setTimeout(2000, relay2_ON); // delay 2sec then turn on relay2
timer.setTimeout(15000, relays_OFF); // delay 15sec from first action and turn off both relays
void relay1_ON(){
digitalWrite(relay1,HIGH); // turn on relay1
Blynk.virtualWrite(V10, 255); // turn on an LED widget (optional)
void relay2_ON(){
digitalWrite(relay2,HIGH); // turn on relay2
Blynk.virtualWrite(V20, 255); // turn on an LED widget (optional)
void relays_OFF(){
digitalWrite(relay1,LOW); // turn off relay1
digitalWrite(relay2,LOW); // turn off relay2
Blynk.virtualWrite(V10, 0); // turn off an LED widget (optional)
Blynk.virtualWrite(V20, 0); // turn off an LED widget (optional)
Run actionRelays() anywhere in your code and it will automatically do the timed sequence without blocking.
Just what I need too. But if I want to repeat it, say 45 times and then stop, what do you suggest?
I could calculate all the intervals and just continue the scetch 45 times, but there must be an easier way, right?
If you want to repeat the entire thing 45 times, then you would just tell it to run again at the end of the sequence.
int repeatCounter;
void relays_OFF(){
repeatCounter++;
if(repeatCounter >= 45){
actionRelays();
repeatCounter = 0;
int setTimer(long d, timer_callback f, int n) Call function f every d milliseconds for n times. The callback function must be declared as void f(). After f has been called the specified number of times, the interval is deleted, therefore the value timerId is no longer valid.
To use that type of trigger he would run out of available space in his timer node.
He only get 10 timers which can be stored at once. After 6 seconds all slots would be full and all new timers would be ignored.
You could set the interval to exactly 15 seconds to match the timed sequence and then it might be fine.
