@psoro Post your Webhook screenshot, Full URL (no need to hide Auth for Local Server), source and target vPin particulars (what are you trying to send to what).
Oh, wait… I think I see… I tried something similar. You can not use another button on the same pin (as the Webhook) as all that happens is the buttons state is sent
If I am understanding correctly, what you need to do is set the “activation” button to a different vPin, and use a corrisponding BLYNK_WRITE() function to call the Webhook Widget’s vPin with whatever data you want to send via Blynk.virtualWrite() and then in the Webhook widget, use the /pin/ method.
No not code free, and thus similar to the Bridge method but it works.
And don’t forget the port in the URL… it is essential from my tests, even when everything is inside the network.
What is your local server version?
Probably @Gunner is right. Support multiple widgets on the same pins is very new feature, so it wasn’t tested for all possible cases yet .
That will not work… at least it doesn’t for me. The button state on the same vPin overrides your webhook payload, but since you are not using the /pin/ you will not even see that result.
But if you do as I mentioned above, then it shouild work.
Mmm…but, in that case, I shouldn’t had success using the Cloud Server and, doing the same thing the result was ok.
Once I pressed the button the info was sent to the other project…
Not quite the same, I was trying to use a new button to instigate transfer from a different data source … that obviously will not work without code, as the new button’s state overrides the intended data source.
And on that note, NO, I didn’t “modify” any code (AKA compile and upload) as I already had a running sketch, so I simply added the Webhook widget, assigned it to an existing display’s vPin and pointed it via the URL to another added Display on another project.
In fact, perhaps becasue I didn’t modify my existing sketch, and thus didn’t have any corresponding BLYNK_WRITE() for when I tested an added button on same vPin as the Webhook… that might have been a contributing issue?
Dear @Gunner., @Toro_Blanco and @Dmitriy …
Now it’s working properly even at Local Server… I was blind trying to use my public IP when obviously, the local IP is enough…
I’m really sorry for wasting your time…
Many thanks to all of you for your help and all the test you did…
It is usually the littlest thing that trips us up The public IP might still work with proper port and forwarding, but if not needed outside the network then why bother.
