Trigger Webhook widget to PUT data to other Blynk Project
Sure, no problem.
These two projects are running on devices in two different locations. Both on my account. Although it probably doesn’t make a difference. I am using the blynk server.
The url in the webhook is (except with my actual auth_token): http://blynk-cloud.com/auth_token/update/v1?value=test123
I can stop project 1 change the text after the "= " re-start project 1, press the button and whatever text I input is displayed on project 2.
Value Display Setting On Project 2 (receiving):
Button Setting on Project 1 (sending):
Webhook Setting on Project 1:
Project 2 with received value (test123):
