Tow ultrasonic
hello iam trying this code withe tow ultra sonic
but it.s not working any help ?
// defines pins numbers
const int trigPin = 13;
const int echoPin = 14;
const int trigPinn = 12;
const int echoPinn = 15;
const int threshold = 50;
// defines variables
long duration;
long duration1;
int distance;
int distance1;
float h;
char auth[] = "";
pinMode(14, OUTPUT);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(trigPinn, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPinn, INPUT);
Serial.begin(9600); // Starts the serial communication
Blynk.begin(auth, "am", "00009999", "blynk-cloud.com", 8442);
int data()
 // Clears the trigPin
digitalWrite(trigPin, LOW);
digitalWrite(trigPinn, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
digitalWrite(trigPinn, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration1 = pulseIn(echoPinn, HIGH);
// Calculating the distance
distance= duration*0.034/2;
distance1= duration1*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
Serial.print("Distance1: ");
Serial.println(distance1);
 if (distance > threshold){
digitalWrite(14, HIGH);
delayMicroseconds(90000);
digitalWrite(14, LOW);
Blynk.virtualWrite(1, distance);
return(distance);
   data();
You need to move the call to the data() function out of the void loop, and either call the function with a timer, or when you press a button widget in the app (depending on what it is would hoping to achieve).
Read this for more info:
the problem is the second ultrasonic is always give 0 value
Believe me, that isn’t your biggest problem as far as this code is concerned.
is that possible that the one of ultrasonic work when i just attached the echo pin
Have you read and understood the document I linked to, and realised how this applies to your code, and what you need to do to restructure your code?
is that better ?
const int trigPin = 12; //6
const int echoPin = 15; //8
const int trigPin2 = 13;
const int echoPin2 = 14;
long duration;
int distance;
long duration2;
int distance2;
char auth[] = "";
void myTimerEvent()
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
distance2= duration2*0.034/2;
Serial.print("Distance2: ");
Serial.println(distance2);
Blynk.virtualWrite(2, distance2);
timer.setInterval(5000L, myTimerEvent);
Looks much better.
Not sure about port 8442 for the Blynk cloud server though.
Does it work?
it’s worke fine but lookabout how iconnect the tow ultrasonic
just the echo pin from every sensore and its work !
