To Read Potentiometer Value
Ok so there is no specific code within your sketch for analogue readings which should be fine as Blynk should just read the port and display it.
When you make reference to ‘corner’ are they the max, min and centre positions on the pot?
In the Value Display what read frequency do you have (PUSH, 250ms up to 59 seconds)?
