I use Blynk on a phone and a tablet but try to limit it to one device at a time.
When the phone is not running Blynk and I change the times in the Timer Widget and press the Play icon it doesnât appear to be processing the widget correctly. I can understand that the App will get confused if 2 devices are logged in at the same time and you change the Timer Widget settings. On the phone with the tablet logged out the Timer Widget is working fine.
Both devices are Samsunsgâs. An S3 with Android 4.4.4. and a GT-P5110 (Tab 2 10.1) with Android 4.2.2.
Come to think of it Iâm not sure the tablet has every responded to the timer widget.
Has anyone else experienced this or have a fix?
I havenât tried the share App with a friend as my app is not quite finished but Iâm guessing friends will not be able to change the time settings in the widget.Obviously we donât want friends to be able to change the app but changing on / off times would be VERY useful. Saves us having to code timers ourselves.
I shared my project with my wife (Alcatel smartphone with Android 4.4.2) and the timer widget doesnât function on that device either. It is the first project I have shared and I was a little surprised that I had to change the auth token in my Arduino Nano for it to work at all.
I guess auth tokens issues will be sorted for makers / families / businesses etc in due course.
So back to the timer widget. In the Alcatel phone it also provides seconds and AM and PM settings for the time setting. Tried AM and PM but still no response from the App. All the other features of the app are working fine.
Pavel I donât really have anything other than what is in the thread already. 3 different devices with 3 different versions of Android. 1 works, 2 donât. The timers donât start at the set time.
Presumably the âtimeâ in question is the time on the Android phone rather than your server.
2 devices using the same account, 3rd device using shared project with a separate account. It is the original device that set up the project (Samsung S3) that works. At a given time my central heating comes on, when the timer widget works.
Yes the timer widget works (on 33% of my machines). I only have one real project so I canât say if it is project specific.
Pavel the auth token was a separate observation on how you share projects. As others have pointed out not very useful for many real world applications. We want to sell thousands of devices with a single app being able to control all the devices. At present each device requires a different sketch.
Timer turns on/off something connected to an Arduino at a given time. Correct?
From what I understood: timer triggers the event(heating) which means that it works.
When you say it doesnât work on 66% of my devices, what do you mean? You canât change time? Time is not updated? Sorry, but Itâs not clear for me.
Arduino send 433 Mhz RF signal to my home heating system.
On 2 of the 3 devices when I set the time say 14:00 on and 14:10 off it doesnât do anything at the allocated time. On the one device it does what my sketch requests i.e. sends the RF signal.
I tried to take photos of my dashboard but the pictures were rubbish. However taking photos of one Android with another Android has helped identify the timer problem.
Using the Samsung phone and Samsung tablet with a single Blynk account I noticed one of the tablet that wasnât responding to the timer widget earlier is now accepting them. It is accepting the timer widget settings from the S3 phone. The time on the 2 devices is about 2 minutes apart and the tablet that is 2 minutes fast is activating the timer widget based on the time of the S3 phone rather than itâs own time, even though the timer widget settings were changed on the tablet.
Just to be clear on the sharing. The Alcatel device received the tiny url (QR) and the Samsung devices (phone and tablet) are using my single account, not my wifeâs.
Canât test the Alcatel (wifeâs account) at present because of the âtoken issuesâ but I suspect this may also be due to different times on the Android devices. I know it should take the time form the device the app is running on but it certainly doesnât seem to when using one account on 2 devices, even with the âmasterâ logged out.
Just done further testing with the Samsungs using the SINGLE account.
S3 time is 16.06 and Tablet is 16.09. If I set Tablet to use the timer for 1 minute from 16:10 to 16.11 it WAITS until the time of the S3 reaches 16:10 to activate, thereby reading 16.12 on the tablet. This timing anomaly was the reason that the timers didnât appear to be working when I tested them earlier.They are working but not based on the time of the device that the app is running on.
The Alcatel time is a further 5 minutes out so that probably explains why they werenât working on that device either with a âQRâ shared app. Strange behaviour.
Just to add I have checked the app sharing feature and I shared it to the Alcatel device with full access rather than just the ability to use the app. Obviously the timer widgets canât be changed if I only give user access but I will take a look at this feature too so I have more of an idea how token work.
All 3 Android devices work! But they donât work as per spec. Looks like they are taking local internet time rather than phone time. I thought all my Android devices were working to local internet time but oviously not as they are up to 6 minutes different. I suspect my main machine, the S3, is actually using local internet time but the others are not. That is why the S3 worked as expected but the others were not triggering as the time had already passed or was due t trigger many minutes after I expected them to.
In a real life situation this âfeatureâ is not too much of a problem as you would be setting the trigger times well into the future and wouldnât notice if it triggered 5 minutes earlier than expected.
Yes they appear to be, even though we were told it was the time on the phone.
What it could be is that when the App first sees the Timer Widget it checks Blynk server time and works out how far in the future the timer should activate. If phone and Blynk servers have different times (i.e. not both updated by the internet) then the timer will start at the âwrongâ time.
Blynk needs to update us with what the ârealâ time is for the timers.
