I’m using an arduino uno with ethernet shield along with some clipon coil current sensors for a power meter solution on a boat (along with some temp/humidity). I’ve got almost everything working but I’m stuck trying to get a “time since reset” display for my kilowatt hour counter. So far my process has been to use the rtc to get a start time and then use the difference between the start time and now() to get a run time. problem is I want to have the start time saved to blynk so that the reboots wont restart the timer.
Pretty embarrassed by the state of my code since i’m definitely a copy paste coder but hopefully someone can see through the mess to point me in the right direction
#include <TimeLib.h>
#include <Ethernet.h>
#include <WidgetRTC.h>
#include "DHT.h"
#include "EmonLib.h"
WidgetRTC rtc;
#define DHTPIN A5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
EnergyMonitor emon1, emon2;
#define W5100_CS 10
#define SDCARD_CS 4
double kilos = 0;
unsigned long startTime;
unsigned long runTime;
char auth[] = "be7167e86b374047be1414f12a05cb16";
BLYNK_WRITE(V3)
kilos = param.asInt();
BLYNK_WRITE(V13)
startTime = param.asInt();
BLYNK_WRITE(V10)
int resetButton = param.asInt();
if (resetButton == 1){
kilos = 0;
startTime = now();
Blynk.virtualWrite(V13, startTime );
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
void myTimerEvent()
Blynk.virtualWrite(V10, millis() / 1000);
double Irms1 = emon1.calcIrms(1480); // Calculate Irms only
double Irms2 = emon2.calcIrms(1480); // Calculate Irms only
int Power = (Irms1 + Irms2) * 120;
kilos = kilos + (Power * (2.05/60/60/1000));
Blynk.virtualWrite(V0, Irms1);
Blynk.virtualWrite(V1, Irms2);
Blynk.virtualWrite(V2, Power);
Blynk.virtualWrite(V3, kilos);
float h = dht.readHumidity();
float f = dht.readTemperature(true);
float hif = dht.computeHeatIndex(f, h);
Blynk.virtualWrite(V4, f);
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, hif);
Blynk.virtualWrite(V7, (kilos * 0.15));
runTime = now() - startTime;
Blynk.virtualWrite(V12, runTime );
emon1.current(0, 30);
emon2.current(1, 30);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V13);
rtc.begin();
