Hey all-
I’m having a sort of ‘Blynk best practices’ issue with a project I’m working on. To summarize it, I have a physical button that, when pressed (needs to be constantly detected for input), tells a piston to move, delays time until the piston is done moving, turns a filler machine on, and stops the filler when the weight needed (FSR analog input- needs to be constantly monitored/refreshed after the filler machine has been enabled) or a specific time interval has lapsed (in case the fsr fails)
I’m posting my code here- it… doesn’t work. I feel like I’m shooting in the dark a bit- if anyone can give some input / words of wisdom, that would be excellent.
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
//Physical Connections:
//D1 on ESP to IN1 on RELAY Board
//D2 on ESP to IN2 on Relay Board
int pistonTimer = 0;
int augurTimer = 0;
//test environment
char auth[] = "1111";
char ssid[] = "blumpkin";
char pass[] = "blah";
WidgetLED pistonLED(V1);
WidgetLED augurLED(V2);
//Physical Buttons
const int buttonLeft = D5;
const int buttonRight = D6;
//TRACKING BUTTON STATE
int leftButtonState = 0;
int rightButtonState = 0;
//OUTPUTS TO RELAY BOARD
const int relayPiston = D1;
const int relayAugur = D2;
bool augurEnabled = false;
//Safe machine startup delays
int augurDelay = 1;
int pistonDelay = 1000;
float fsrSetting = 3.3;
float sensorValue;
float fsrValue = 0;
bool fsrWeight = false;
unsigned long currentMillis = millis();
bool timerToggle = false;
//augurDelay from Blynk Slider
BLYNK_WRITE(3) {
int setting = param.asInt();
augurDelay = setting;
//piston delay from blynk slider
BLYNK_WRITE(4) {
pistonDelay = setting;
//Voltage setting from blynk slider
BLYNK_WRITE(8) {
float setting = param.asFloat();
fsrSetting = setting;
void disableAugur() {
timer.disable(augurTimer);
digitalWrite(relayAugur, HIGH);
augurLED.off();
Serial.println("E");
void enableAugur() {
timer.disable(pistonTimer);
digitalWrite(relayAugur, LOW);
Serial.println("B");
augurLED.on();
if ((fsrWeight) || ((currentMillis - previousMillis) > augurDelay)) {
Serial.println("D");
disableAugur();
enableAugur();
Serial.println("C");
// Serial.begin(9600);
pinMode(A0, INPUT);
pinMode(buttonLeft, INPUT_PULLUP);
pinMode(buttonRight, INPUT_PULLUP);
pinMode(relayPiston, OUTPUT);
digitalWrite(relayPiston, HIGH);
pinMode(relayAugur, OUTPUT);
augurLED.off();
WiFi.mode(WIFI_STA);
WiFi.begin("blumpkin", "blah");
ArduinoOTA.setHostname("Augur Controller");
ArduinoOTA.begin();
delay(2000);
//Enable for Farm
//Blynk.begin(auth, ssid, pass, "192.168.1.50");
//Test mode Blynk connection
BLYNK_CONNECTED() {
Blynk.syncVirtual(V3, V4, V8);
ArduinoOTA.handle();
sensorValue = analogRead(A0);
fsrValue = sensorValue * ( 3.3 / 1023.0);
//Tests whether scale is at-weight or not
if (fsrValue > fsrSetting) {
fsrWeight = true;
fsrWeight = false;
leftButtonState = digitalRead(buttonLeft);
rightButtonState = digitalRead(buttonRight);
if (leftButtonState == 0 && augurEnabled == false) {
augurEnabled = true;
Serial.println("A");
previousMillis = millis();
pistonLED.on();
//This gives piston a specific time to extend/retract before turning augur on
pistonTimer = timer.setTimeout(pistonDelay, enableAugur);
if (rightButtonState == 0 && augurEnabled == false) {
pistonLED.on();
//This give piston a specific time to extend/retract before turning augur on
void dummyfunction() {
