Timer not defined in scope
While compiling iam getting error which says the timer not defined help me
// WiFi credentials
char ssid[] = "your_SSID";
char password[] = "your_PASSWORD";
// Blynk auth token
char auth[] = "your_AUTH_TOKEN";
#define SENSOR_PIN   A0   // Proximity sensor pin
#define BUZZER_PIN   D8  // Buzzer pin
// Keep track of the state of the bin (empty or full)
bool binEmpty = true;
// Keep track of the last time the buzzer was triggered
unsigned long lastBuzzTime = 0;
// Timer object to trigger buzzer
int rotor_PWM = 6;  // Digital/PWM pin 6 to the LPWM on the BTS7960
// Enable rotor movement
int rotor_EN = 7;  // connect Digital/PWM pin 7 to L_EN on the BTS7960
int stop1 = 0;
int stop2 = 1;
int back1 = 2;
int back2 = 3;
int pwm1 = 4;
int pwm2 = 5;
  // Initialize serial port for debugging
  // Connect to WiFi network
  Blynk.begin(auth, ssid, password);
  WiFi.begin("your_wifi_ssid", "your_wifi_password");
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  // Initialize the Blynk IoT platform with the auth token
  Blynk.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str());
  // Initialize the proximity sensor pin as an input
  pinMode(SENSOR_PIN, INPUT_PULLUP);
  // Initialize the buzzer pin as an output
  pinMode(BUZZER_PIN, OUTPUT);
  // Set up the timer to trigger every 5 seconds
  timer.setInterval(5000L, timerFunction);
pinMode(stop1, OUTPUT);
  pinMode(stop2, OUTPUT);
  pinMode(back1, OUTPUT);
  pinMode(back2, OUTPUT);
  pinMode(pwm1, OUTPUT);
  pinMode(pwm2, OUTPUT);
  pinMode(rotor_PWM, OUTPUT);//rotor pin setup
  pinMode(rotor_EN, OUTPUT);
BLYNK_WRITE(V0)//FORWARD
  if (param.asInt() == 1) {
    forward();
    Stop();
BLYNK_WRITE(V1)//BACKWARD
    backward();
    Stop();
BLYNK_WRITE(V2)//LEFT
    left();
    delay(2900);
    Stop();
BLYNK_WRITE(V3)//RIGHT
    right();
    delay(2900);
    Stop();
BLYNK_WRITE(V4)//STOP
    Stop();
BLYNK_WRITE(V6)//SPEED MODE
    Sforward();
BLYNK_WRITE(V7) // 180 degree
  if (param.asInt() == 1){
   cright();
   delay(5900);
    Stop();
BLYNK_WRITE(V8) // ROTOR START
   rotor_start();
BLYNK_WRITE(V9) // ROTOR STOP
   rotor_stop() ;
void Stop()
  analogWrite(pwm1, 0);
  analogWrite(pwm2, 0);
void left(){
  analogWrite(pwm1, 200);
  digitalWrite(back1, LOW);
  digitalWrite(back2, LOW);
  analogWrite(pwm2, 200);
void right() {
  digitalWrite(back1, HIGH);
  digitalWrite(back2, HIGH);
void cright() {             //180 degree
void backward() {
void forward() {
void Sforward() {
  analogWrite(pwm2, 70);
  analogWrite(pwm1, 70);
void rotor_start() {
  analogWrite(rotor_PWM, 255);
  digitalWrite(rotor_EN, HIGH);
void rotor_stop() {
  analogWrite(rotor_PWM,0);
  digitalWrite(rotor_EN, LOW);
void timerFunction() {
  // Read the state of the proximity sensor
  int sensorState = digitalRead(SENSOR_PIN);
  // If the sensor is triggered (object in front of it)
  if (sensorState == LOW) {
    // If the bin was empty before, set the bin state to full, and send a message to the Blynk app
    if (binEmpty) {
      binEmpty = false;
      // Send the message to the Blynk app
      Blynk.virtualWrite(V0, "Bin inserted");
    // Reset the buzzer trigger timer
    lastBuzzTime = 0;
    // If the sensor is not triggered (no object in front of it)
    // If the bin was full before, set the bin state to empty, and send a message to the Blynk app
    if (!binEmpty) {
      binEmpty = true;
 // Check if it's time to trigger the buzzer
  if (millis() - lastBuzzTime > 5000L && binEmpty) {
    // Trigger the buzzer twice and send a message to the Blynk app
    digitalWrite(BUZZER_PIN, HIGH);
    delay(100);
    digitalWrite(BUZZER_PIN, LOW);
    delay(100);
    delay(100);
    // Set the last buzzer trigger time to the current time
    lastBuzzTime = millis();
Which line of code is highlighted when this happens?
This line shows error
} is missing
Yes but the error comes on timer the timer have so connection with this void function
Yes but bracket is missing!
Your editor don’t know exactly where is the error.
β€˜β€™β€™
β€˜β€™β€™
Ok you decide to ignore my advice , you can wait till your death :joy:
The timer part is not compiling correct way I dont know what to do
Add the missing closing bracket!!
// WiFi credentials
// Blynk auth token
int stop1 = 0;
int stop2 = 1;
int back1 = 2;
int back2 = 3;
int pwm1 = 4;
int pwm2 = 5;
    forward();
    Stop();
    backward();
    Stop();
    left();
    delay(2900);
    Stop();
    right();
    delay(2900);
    Stop();
    Stop();
    Sforward();
   cright();
   delay(5900);
    Stop();
   rotor_start();
   rotor_stop() ;
void Stop()
void left(){
void right() {
void backward() {
void forward() {
void Sforward() {
void rotor_stop() {
    if (binEmpty) {
      binEmpty = false;
    lastBuzzTime = 0;
    if (!binEmpty) {
      binEmpty = true;
    delay(100);
    delay(100);
    delay(100);
This is what are they are suggesting to do. " } " missing bracket.
