Since updating to local server 0.41.5, I’ve noticed that some of my timers do not trigger. Unfortunately this seems very inconsistent.
I have three devices in device tiles, all of which have two timer widgets that set V1 or V2 to 0 or 1. There has been no config changes since upgrading from 0.41.2 local server. I’m going to roll back to 0.41.4 to see if that helps.
The server is running on Ubuntu server 18.10 with OpenJDK 11.0.2 and I can’t see anything out of the usual in the logs.
hi - i am also on 0.41.5 and noticed a few occasions where a timer should have triggered a function, but it did not.
but I thought maybe my code needed a review (it is changing of the seasons here, so my winter code is back in play and it hasn’t been tweaked since 2018)…
i will take a closer look now that you have mentioned this…
// "Sacrificial" Timer - needed when deleting timers as that will kill first timer created...
timer.setTimeout(10L, []() {
}); // END sacrificial Function
