Timer isnt working in the blynk Provisioning.
I have tested the hardware and timer widget with a regular project, connecting the hardware directly to the project and it works. When I use the NodeMCU provisioning, everything is working, Led, Relay, relay + a button, but when I include the timer, doesnt work.
I have also read the virtual pin of the timer, and voila! I found what is happening, or at least I think I found it!
When I check the API URL, the value is โ1โ or โ0โ, but if I change it from the app, nothing happens. Then I went back to some old projects and I realize that the API was reading the project timer and not the app timer, but Relay and NodeMCU is linked to the App timer and not the project timer as in original projects with Blynk.
So I guess, Timer is not working in Blynk Provisioning. The code is as simple as the one in the regular projects, but this one is not working at all.
Any ideas? Here down below the details:
- Search forum for similar topics: I searched a lot but nothing appeared.
- Add details :
โข Hardware model: NodeMCU v3 ESP8266 Lolin1 ยง communication type: WIFI ESP8266
โข Smartphone OS: Android + version 9 (Samsung Galaxy S8)
โข Blynk server
โข Blynk Library version: 0.6.1
My Sketch:
#define USE_NODE_MCU_BOARD
#define APP_DEBUG // Comment this out to disable debug prints
#include "BlynkProvisioning.h"
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V12);
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
Adafruit_BMP280 bme; // I2C
//Registering Led pin 1
WidgetLED led10(V10);
/------------------- Global Variables --------------------------
int AmbTemp = 0;
void requestTime() {
Blynk.sendInternal("rtc", "sync");
BLYNK_WRITE(InternalPinRTC) {
long t = param.asLong();
Serial.print("Unix time: ");
Serial.print(t);
terminal.println(t);
Serial.println();
delay(500);
pinMode(14, OUTPUT);
Serial.println(F("BMP280 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1);
timer.setInterval(10000L, requestTime);
BlynkProvisioning.begin();
void sendSensor(){
int TempNow;
Serial.print("T=");
Serial.print(bme.readTemperature());
Serial.println(" *C");
TempNow = bme.readTemperature();
Blynk.virtualWrite(V6, TempNow);
AmbTemp = bme.readTemperature();
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= 5000) { //envia la temperatura cada 5 segundos
BlynkProvisioning.run();
BLYNK_WRITE(V3) { //Blynk Timer Widget
if (param.asStr()=="1") {
//HIGH
Serial.println(">>>> Sistema Temporizador Accionado <<<<<");
pin_activated();
//LOW
pin_deactivated();
void pin_activated(){
led10.on(); //LED 10 "HIGH"
digitalWrite(14, 1); //relay is on
Serial.println("Pin Activado");
sendSensor();
void pin_deactivated(){
led10.off(); //LED "LOW"
digitalWrite(14, 0); //relay is off
Serial.println("Pin Desactivado");
sendSensor();
