Yes exactly - and that’s the example I used.
But just defining a second timer makes the board crash.
try not to define the t1 and t2.
Just declare them as int’s .
int t1, t2;
Pls help me…i have this error and i not understand
exit status 1
‘param’ was not declared in this scope
What ??
Thanks, i solved the problem
i have last question about this function
Now if i Press a botton (V12)
Relay Pin D5 start cycle and work is good!
but now i need to add other relay (when V12 are switch on) without cycle…only turn on
situation :
V12 ON
D5 pin cycle time
D6 pin turn on
V12 OFf
D5 Off
D6 Off
Can you help me to undestatand ths?
@Lufkin you want to control 2 relays, correct?
Are the 2 relays in any way connected in your project or are they both independent of each other?
If they are independent I would just duplicate all the code and make a minor adjustment to the variable names for the 2nd relay.
Hi Fettkeewl
i have a question
in your code if i press ON button, start with 20sec OFF and 10 ON
but i need to place inverse time…
when start — >> 20sec ON and 10 off
but i not understand …can you help me??
Thanks very very much
Just swap theese values
