Time out di koneksi blynk
selamat malam…sy tidak bisa tersambung di “cloud blynk.com” selalu penjelasan nya
penjelasan nya selalu seperti ini:
20:52:51.195 -> [1015152] Connecting to blynk-cloud.com:80
20:52:54.216 -> [1018163] Login timeout
mohon bantuannya
note :saya menggunakan NodeMCU ESP2866 12E
ini ada code examples yang sy gunakan
@HAMDAN please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
mohon pengarahan nya…
I gave you triple backticks to copy and paste, but you have used different characters, which do not work.
Please edit your post and use the correct characters otherwise your unformatted code will be deleted.
