Time input with blynk 1.23.1 (203)
Merci beaucou de votre réponse prècise, et rapide !
j’avais un ancien compte mais je pensais qu’il n’était plus compatible avec le nouveau Blink, je l’ai donc annulé ! (avec des modules suplèmentaires que j’avais achetés) pour le refaire en nouvelle version.
40 donnèes par heure, je vais faire avec (je vais supprimer l’hydromètrie pour privilègier la tempèrature)
Maintenant, je n’ai plus qu’à attendre que Blink se débloque et gérer mon chauffage manuellement (pas facile car leur système AIRTON ne respecte pas du tout la consigne que l’on leur donne, on envoie 17° et dans la pièce cela monte jusqu’à +23 ! ! !, elle ne s’arrête presque jamais quelque soit la tempèraturede consigne et cela sur toutes mes 6 clims)
Thank you very much for your precise and quick response!
I had an old account but I thought it was no longer compatible with the new Blink, so I canceled it! (with additional modules that I had purchased) to redo it in a new version.
40 data per hour, I will make do with it (I will remove hydrometry to favor temperature)
Now, I just have to wait for Blink to unblock and manage my heating manually (not easy because their AIRTON system does not at all respect the instructions given to them, we send 17° and in the room that goes up to +23!, it almost never stops whatever the set temperature and this on all my 6 air conditioning units)
Yes, on the top banner there is a message that I have reached the message limit, I will have to wait until December 27 for it to reset! ! !
Maybe you should take the time between now and then to write code correctly, so that you don’t do the same thing again when your new message allowance is available.
You need to stop calling Blynk.syncVirtual in your void loop, and using Blynk Timer as explained in the link I provided. You’ll need to make very infrewuent timed Blynk.virtualWrites and allow some leeway for messages from your app.
Thank you again, I will take note of your comments.
