Time input widget stop time inability?
What is actually happening at your end Mike?
I put time for Start - Stop ( in advance ) and when time comes, never activate the relay or even the virtual switch indication at Blynk app … What to do? I am dried from ideas… Is it possible to have something to do with my Blynk auth key???
Also, now I observed that V16 (and only this) change color at the small switch ring from green to red by itself …
@mikekgr it is working fine on Blynk’s server for me. I will send you the sketch.
yes please!
@Costas @Dmytro
Finally, after many hours of debugging / bug hunting and with the GREAT HELP of Costas, I change the Blynk auth as the last measure against this unbelievably problem. And that was, something at the public Blynk server did not not like my “old” auth …
Now, everything are back to normal.
Again, thanks a lot Costas for your support.
Best Regards,
Mike Kranidis
@Dmytro @vshymanskyy
Dear Sirs,
Recently I notice something ( I have Android App latest version 2.0.3 (code:91) to both of my smartphone and arduino library 0.4.2 ) , using the Time Input widget when I go to “Set the time” page and select RESET at START AT ( --:-- ) and RESET at STOP AT ( --:-- ) and finally tap OK to return back to project layout.
So far so good right? No, I observed that the other smartphone of mine does not change the particular timer time settings ( should be say --:-- - --:-- but it has the latest value just before the adjustments above ( the RESET settings ). Also if I stop / start the project, the time has the latest value just before the adjustments above.
I suspect some bug here. Please see and let me/us know!
P.S. this behavior is sketch irrelevant…
Thanks and Best Regards,
Mike Kranidis
Thanks for reporting.
2.0.4 as you know the problem is solved!!!
:wink:
