what should I do now?
Aside from all the prior suggestions? I don’t know… how did they work out first?
Will it work on another board. For example nodemcu ESP8266?
Will what work? the Time Input Widget?? Yes, it is just a simple data transfer widget and will work on any device that can run Blynk… it is your code that takes the widget’s input and makes it work… again on any device.
hello. can someone reply me the code of time input included digital pin 13 (led). connection to blynk - usb. thank you in advance
You already have a topic about this… and we do not exist to custom make your code
I know:joy: But example code is just useless. How it will control something when there is no digital pin written!!
We already showed you the resources you need to learn that, in this topic… of which I merged your last few posts back into.
Or… as I also already stated… if you just want a dirt simple timer to control a pin, use the Timer Widget or even Eventor.
I need to set days too and timer widget doesn’t have this option
Then look back up in this topic and start re-reading the Advanced Time Input references.
#include <WidgetRTC.h>
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char currentTime[9];
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
WidgetRTC rtc; // Set RTC widget.
pinMode(2, OUTPUT); // Built-in LED
digitalWrite(2, HIGH); // Turn OFF built-in LED
Serial.begin(115200); // Debug console
rtc.begin();
setSyncInterval(360);
timer.setInterval(30000L, TimeCheck); // Update Time Check every 30 seconds
BLYNK_CONNECTED() {
Blynk.syncVirtual(V1); // Synchronize Time Input Widget when connected
TimeCheck(); // Initial Time Check
BLYNK_WRITE(V1) { // Called whenever setting Time Input Widget
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
void TimeCheck() { // call with timer every 30 seconds or so
// Get RTC time
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
Serial.print("Current Time: ");
Serial.println(currentTime);
// Get Time Input Widget time
sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec);
Serial.print("Start Time: ");
Serial.println(startTime);
sprintf(startTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec);
Serial.print("Stop Time: ");
if (hour() == SThour) {
if (minute() == STmin) {
Serial.println("Doing something now");
digitalWrite(2, LOW); // Turn ON built-in LED
} else if (minute() < STmin) {
Serial.println("Will do something");
} else if (minute() > STmin) {
Serial.println("Did something");
Serial.println("Clueless");
if (hour() == SPhour) {
if (minute() == SPmin) {
Serial.println("Stopping something now");
} else if (minute() < SPmin) {
Serial.println("Will stop something");
} else if (minute() > SPmin) {
Serial.println("Stopped something");
Serial.println("----------");
Will it work if I change this code for usb connection?
Sure, why not. But you have to account for other factors concerning UNO vs ESP8266 as well… like changing the Blynk library file used and GPIO pin numbering.
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
pinMode(13, OUTPUT); // Built-in LED
digitalWrite(13, LOW); // Turn OFF built-in LED
Serial.begin(9600); // Debug console
Blynk.begin(Serial, auth);
rtc.begin();
BLYNK_CONNECTED() {
// Get RTC time
digitalWrite(13, HIGH); // Turn ON built-in LED
there is something wrong
heelp
