Time input as Alarm Clock
Hello, my name is Rafael Borges, I am trying to set the time input widget as an alarm clock, but I have read some topics here and still having some trouble.
I wish I could turn relays on pins Digital 2 and 4 on when the time hits the time I’ve set on time input widget V0.
Is it possible to do that?
This is the code I’m trying to use, provided by COSTAS
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use Arduino Ethernet shield (W5100)
 * to connect your project to Blynk.
 * Feel free to apply it to any other example. It's simple!
 * NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
 *       DON'T use them in your sketch directly!
 * WARNING: If you have an SD card, you may need to disable it
 *       by setting pin 4 to HIGH. Read more here:
 *       https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
#include <Thermistor.h>
#include  <Time.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "XXXX";
char Date[2];
char Time[2];
#define W5100_CS  10
#define SDCARD_CS 4
Thermistor temp(0);
long startseconds;            // start time in seconds
long stopseconds;             // stop  time in seconds
long nowseconds;              // time now in seconds
int btnpin;
WidgetRTC rtc;
BLYNK_ATTACH_WIDGET(rtc, V0);
void myTimerEvent()
    int temperature = temp.getTemp();
  Blynk.virtualWrite(3, temperature);
void setup(){
    Serial.begin(115200);         // COSTAS
    Serial.println("\nStarted");  // COSTAS
    pinMode(2, OUTPUT);
    Blynk.begin(auth);
    while (Blynk.connect() == false) {     // COSTAS
      // Wait until connected              // COSTAS
    }                                      // COSTAS
    Blynk.notify("Connected successfully");
    Serial.println("Done");
    rtc.begin();
    timer.setInterval(60000L, activetoday);     // check every minute if schedule should run today
    timer.setInterval(30000L, reconnectBlynk);  // check every 30s if still connected to server
    timer.setInterval(1000L, myTimerEvent);     // check room temperature every second
 void activetoday(){        // check if schedule should run today
     if(year() != 1970){
        Blynk.syncVirtual(V1); // sync timeinput widget
        sprintf(Date, "%02d/%02d/%04d",  day(), month(), year());     // COSTAS
        sprintf(Time, "%02d:%02d:%02d", hour(), minute(), second());  // COSTAS
BLYNK_WRITE(V1) {
    TimeInputParam t(param);
    Serial.print("Checked schedule at: ");
    Serial.println(Time);
    int dayadjustment = -1;
    if(weekday() == 1){
        dayadjustment =  6; // needed for Sunday, Time library is day 1 and Blynk is day 7
    if(t.isWeekdaySelected((weekday() + dayadjustment))){ //Time library starts week on Sunday, Blynk on Monday
         Serial.println("Schedule ACTIVE today");
          nowseconds = ((hour() * 3600) + (minute() * 60) + second());
          startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
          if(nowseconds >= startseconds){
                   if(nowseconds <= startseconds + 90){    // 90s on 60s timer ensures 1 trigger command is sent
                            // code here to switch the relay ON
                            digitalWrite(2, HIGH); // set Relay ON
                            Blynk.virtualWrite(V2, 1);
          else{
              Serial.println("Relay not on");
              // nothing more to do here, waiting for relay to be turned on later today
          stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
          if(nowseconds >= stopseconds){
                  if(nowseconds <= stopseconds + 90){
                          // code here to switch the relay OFF
                          digitalWrite(2, LOW); // set Relay OFF
                          Blynk.virtualWrite(V2, 0);
          else{
                  if(nowseconds >= startseconds){  // only show if motor has already started today
                              Serial.println("Relay is still ON");
                              // nothing more to do here, waiting for motor to be turned off later today
    else{
        Serial.println("Schedule INACTIVE today");
        // nothing to do today, check again in 1 minutes time
    Serial.println();
void reconnectBlynk() {
    if (!Blynk.connected()) {
      if(Blynk.connect()) {
          BLYNK_LOG("Reconnected");
      else {
          BLYNK_LOG("Not reconnected");
BLYNK_WRITE(V2) {
     btnpin = param.asInt();
     digitalWrite(2, btnpin);
    if (Blynk.connected()) {
But i’m not getting the serial print to see if the time input is set for today, also I can’t see the time the wigdet is set after the correction, so I don’t know if it is correct for my timezone
@borges_rafa as per the other thread the RTC widget has recently changed so the code you have will need to be modified. See the latest RTC example provided by Blynk and if you are still struggling let me know and I will look through your revised sketch.
