Time Based Automation With Conditional Check
I have seen a couple threads but they are from 2021 so seeing if there is new info out. I am hoping to use the time based automation to trigger my irrigation system through my blynk project. I have the automation all setup and it works great. I have used an Open weather api and json to trigger a switch in blynk for when it is raining or not. I was hoping to add that to the automation as a conditional check. I know there is a rule builder for the enterprise plan. I am on the pro plan and do not see that feature. Is that the only way to get access to this currently?
