#include <ESP8266_Lib.h>
#define RELAY_PIN_1 12 //D6
#define RELAY_PIN_2 16 //D0
#define VPIN_BUTTON_1 V12
#define VPIN_BUTTON_2 V13
int relay1State = LOW;
int relay2State = LOW;
char pass[] = "YourPassword";
SoftwareSerial EspSerial(2, 3);
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
RH_ASK rftrans;
BLYNK_CONNECTED()
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
BLYNK_WRITE(VPIN_BUTTON_1)
relay1State = param.asInt();
digitalWrite(RELAY_PIN_1, relay1State);
BLYNK_WRITE(VPIN_BUTTON_2)
relay2State = param.asInt();
digitalWrite(RELAY_PIN_2, relay2State);
void checkPhysicalButton()
uint8_t buf[2];
uint8_t buflen = sizeof(buf);
if (rftrans.recv(buf, &buflen))
if ((char*)buf == "ze")
else if ((char*)buf == "on")
relay1State = !relay1State;
Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
else if ((char*)buf == "tw")
relay2State = !relay2State;
Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
else if ((char*)buf == "th")
else if ((char*)buf == "fo")
else if ((char*)buf == "fi")
else if ((char*)buf == "si")
else if ((char*)buf == "se")
else if ((char*)buf == "ei")
else if ((char*)buf == "ni")
else if ((char*)buf == "aa")
else if ((char*)buf == "bb")
else if ((char*)buf == "cc")
else if ((char*)buf == "dd")
else if ((char*)buf == "st")
else if ((char*)buf == "ha")
rftrans.init();
pinMode(RELAY_PIN_1, OUTPUT);
pinMode(RELAY_PIN_2, OUTPUT);
timer.setInterval(500L, checkPhysicalButton);
This is a code for integrating RF remote with blynk can anyone check if this code has any major flaws. This project is about controlling relays with BLYNK and RF remote so whenever i change the relay state with the RF remote it should automatically update the state in the app.
I’m a beginner so can anyone help.
the rf codes like “ze”, “on” are the ones i used for my own RF remote using a transmitter so that one you can ignore.
The transmitter code if that’s somehow necessary.
#include <RH_ASK.h>
const byte ROWS = 4;
const byte COLS = 4;
RH_ASK rftrans;
const char *data;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7, 8, 9}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
rftrans.init();
char customKey = customKeypad.getKey();
if (customKey == '0')
data = "ze";
rftrans.send((uint8_t *)data , strlen(data));
rftrans.waitPacketSent();
delay(500);
else if (customKey == '1')
data = "on";
delay(500);
else if (customKey == '2')
data = "tw";
delay(500);
else if (customKey == '3')
data = "th";
delay(500);
else if (customKey == '4')
data = "fo";
delay(500);
else if (customKey == '5')
data = "fi";
delay(500);
else if (customKey == '6')
data = "si";
delay(500);
else if (customKey == '7')
data = "se";
delay(500);
else if (customKey == '8')
data = "ei";
delay(500);
else if (customKey == '9')
data = "ni";
delay(500);
else if (customKey == 'A')
data = "aa";
delay(500);
else if (customKey == 'B')
data = "bb";
delay(500);
else if (customKey == 'C')
data = "cc";
delay(500);
else if (customKey == 'D')
data = "dd";
delay(500);
else if (customKey == '*')
data = "st";
delay(500);
else if (customKey == '#')
data = "ha";
delay(500);
