Thingspeak and Blynk webhook
I am trying to retrieve last updated value from a particular field in Thingspeak channel, but I am unable to get the value(Instead I got channel info as output). This is my code.
char auth[] = "4b1cdbaf3e864bd98b9af0200c50ccf0";
char  ssid[] = "myssid";
char  pass[] = "mypass";
BLYNK_WRITE(V0)
  Serial.println("WebHook data:");
  Serial.println(param.asStr());
  Blynk.virtualWrite(V0, "https://api.thingspeak.com/channels/222225/feeds.json?api_key=7K7N3UA3SA49QPO1&results=1");
this is the output I got for the above code
In Blynk app I have following config:
webhook widget
pin: Virtual V0
URL: /pin/
Method: GET
Content Type: application/json
body: blank
How should I modify my code to get value from a particular field (eg: field1)?
Thank you.
Hello. You using this in wrong way. Url to 3-d party server should be configured in app and in virtual pin you need just to send value. Please check docs.
@Dmitriy Thanks for your reply :slight_smile:
I want to receive the value from 3-d party server not send it. How do I do that?
and is my url correct for reading a value from thingspeak channel?
Thank you
It is also specified in above link. Please read it carefully.
Yes.
It worked. Thanks!
