Сьогодні звернув увагу, що віджет слайдер не працює як раніше.
Перестав ковзатись пальцем повзунок. Треба тицяти пальцем в місце, а повзунок підповзає до того місця.
Нічого не міняв. Оновлювалась сьогодні програма на смартфоні з Google play. І бібліотека була 0.5 бета. До сьогодні все добре працювало.
Today, I noticed that the slider widget does not work as before.
Stop sliding your finger slider. You need to tick your finger in place, and the slider crawls to that place.
Nothing changed. Updated today the program on a smartphone from google plai. And the library was 0.5 beta. To date, everything worked well.
There was a recent fix for some GUI slider issues in older Android versions… And that last Android App (2.17.1) did fix the issue
And although I do see an ever so slight visual slowdown in the slide movement, it doesn’t seem to affect performance.
Perhaps the beta library 0.5.0 might be part of your issue? Have you tried it with the current 0.4.10 release? As that works great on all my tests now.
@s.d.engineering as another topic had already been created, I have moved your post here…
However, can you provide some actual details besides “doesn’t work correctly.” … particularly as I have already tested since last App update and everything is working perfectly for me (however I am NOT using the BETA 0.5.0 Library)
Blynk Library version: 0.4.10
Just checked once again, and the issue is not reptoducible now.
But yesterday I definitely had the issue. Will try to test different scenarios
