Im using node mcu connected with max30100 sensor, lm35,servo, and two switches.
Wen I only run max30100 program it goes well but after combing this code it keeps connecting and disconnecting.
#include <Servo.h>
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
const int selectPins[3] = {D3, D2, D1};
const int analogInput = A0;
char auth[] = "DKzt93WiavmRmSvb1XmSuCTGLgK0oBt2";
char ssid[] = "adik";
char pass[] = "1234567890";
#define REPORTING_PERIOD_MS 3000
PulseOximeter pox;
uint32_t tsLastReport = 0;
WidgetLCD lcd1(V2);
Servo servo1, servo2;
void onBeatDetected()
pinMode(D5, INPUT);
pinMode(D6, INPUT);
pinMode(D6, OUTPUT);
servo1.attach(D8);
servo1.write(0);
lcd1.clear();
for (int i = 0; i < 3; i++)
pinMode(selectPins[i], OUTPUT);
digitalWrite(selectPins[i], HIGH);
Serial.print("Initializing pulse oximeter..");
// Initialize the PulseOximeter instance
// Failures are generally due to an improper I2C wiring, missing power supply
// or wrong target chip
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
digitalWrite(1,HIGH);
pox.setIRLedCurrent(MAX30100_LED_CURR_24MA);
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
timer.setInterval(1000L, getSendData);
BLYNK_WRITE(V5) // V5 is the number of Virtual Pin
int pinValue = param.asInt();
Serial.println(pinValue);
int key1 = digitalRead(D5);
if (key1 == HIGH)
servo1.write(90);
Blynk.notify("Yaaay... Medicine 1 taken!");
delay(2000);
servo1.write(0);
servo1.write(0);
int key2 = digitalRead(D8);
Serial.println(key2);
if (key2 == HIGH)
digitalWrite(D8, LOW);
Blynk.notify("Emergency Alert!");
else {
Serial.println("No Emergency ");
for (byte pin = 0; pin <= 1; pin++)
if (pin == 0)
Serial.println("In Pin =0 ");
digitalWrite(selectPins[i], pin & (1 << i) ? HIGH : LOW);
int inputValue = analogRead(analogInput);
float millivolts = (inputValue / 1024.0) * 3300; //3300 is the voltage provided by NodeMCU
float celsius = millivolts / 10;
Serial.print("in DegreeC= ");
Serial.println(celsius);
Blynk.virtualWrite(V0, celsius);
if (pin == 1)
Serial.println("In Pin =1 ");
Serial.print(" Heart Rate= ");
int BPM = random(78, 98);
Serial.println(BPM);
Blynk.virtualWrite(V1, BPM);
// delay(10000);
// Make sure to call update as fast as possible
pox.update();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
// to computer serial monitor
Serial.print("BPM: ");
Serial.print(pox.getHeartRate());
//blue.println("\n");
Serial.print(" SpO2: ");
Serial.print(pox.getSpO2());
Serial.print("%");
Serial.println("\n");
Blynk.virtualWrite(V6,pox.getHeartRate() );
Blynk.virtualWrite(V7,pox.getSpO2());
tsLastReport = millis();
Serial.println();
delay(3000);
void getSendData()
