The ESP32 connects to the account but immediately reconnects
You are trying to connect the ESP32 to Blynk with the following code:
  This is a simple demo of sending and receiving some data.
  Be sure to check out other examples!
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID           "TMPL4Bq7fmirA"
#define BLYNK_TEMPLATE_NAME         "Quickstart Template"
#define BLYNK_AUTH_TOKEN            "eFwn8uz0it5n5CzTpqckoLtKfmMKyyfq"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "HUAWEI-1BJ76W";
char pass[] = "0974508522serg";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
  // Set incoming value from pin V0 to a variable
  int value = param.asInt();
  // Update state
  Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
  Blynk.setProperty(V3, "onImageUrl",  "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
  Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
  Blynk.virtualWrite(V2, millis() / 1000);
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
  // to avoid delay() function!
The ESP32 connects to the cloud, and even on the quick start website, it’s displayed, but for some reason, the program seems to restart immediately, and in the serial monitor, it shows:
   / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v1.3.2 on ESP32
 #StandWithUkraine    https://bit.ly/swua
[1107] Connecting to blynk.cloud:80
[1206] Ready (ping: 41ms).
ets Jun  8 2016 00:22:57
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4832
load:0x40078000,len:16460
load:0x40080400,len:4
load:0x40080404,len:3504
entry 0x400805cc
[18] Connecting to HUAWEI-1BJ76W
[593] Connected to WiFi
[593] IP: 192.168.3.26
[594]
    ___  __          __
   / _ )/ /_ _____  / /__
[604] Connecting to blynk.cloud:80
[702] Ready (ping: 39ms).
entry 0x400805cc
What does this mean?
What version of the ESP32 core do you have installed?
