Testing Blynk Library new release v1.0.0
The latest new release of Blynk Library v1.0.0 has been published.
I’ve had a preliminary test of Blynk_WM v1.6.0 and it’s so far OK for connection to Blynk Cloud as well as local Blynk server (v0.41.16).
But sure there are many things I haven’t tested (Blynk features, other Blynk-WM-related libraries). Please report the issue to the corresponding libraries, if you have a chance to test and experience issues.
Here after are the terminal outputs for ESP8266 and ESP32 running Blynk_WM v1.6.0
ESP8266WM_MRD_ForcedConfig using LittleFS with SSL on ESP8266_NODEMCU_ESP12E
Starting ESP8266WM_MRD_ForcedConfig using LittleFS with SSL on ESP8266_NODEMCU_ESP12E
ESP8266 core v3.0.0
Blynk_WM SSL for ESP8266 v1.6.0
ESP_MultiResetDetector v1.1.1
[272] Set CustomsStyle to : <style>div,input{padding:5px;font-size:1em;}input{width:95%;}body{text-align: center;}button{background-color:blue;color:white;line-height:2.4rem;font-size:1.2rem;width:100%;}fieldset{border-radius:0.3rem;margin:0px;}</style>
[294] Set CustomsHeadElement to : <style>html{filter: invert(10%);}</style>
[301] Set CORS Header to : Your Access-Control-Allow-Origin
LittleFS Flag read = 0xFFFE0001
multiResetDetectorFlag = 0xFFFE0001
lowerBytes = 0x0001, upperBytes = 0x0001
No multiResetDetected, number of times = 1
Saving config file...
Saving config file OK
[346] Hostname=8266-Master-Controller
[365] LoadCfgFile
[366] OK
[366] ======= Start Stored Config Data =======
[366] Hdr=SSL_ESP8266,BrdName= ESP8266_NODEMCU_ESP12E
[366] SSID=HueNet1,PW=password
[369] SSID1=HueNet2,PW1=password
[372] Server=account.duckdns.org,Token=token
[378] Server1=account.duckdns.org,Token1=token1
[384] Port=9443
[386] ======= End Config Data =======
[389] CCSum=0x384b,RCSum=0x384b
[395] LoadCredFile
[395] CrR:pdata=default-mqtt-server,len=34
[397] CrR:pdata=1883,len=6
[400] CrR:pdata=default-mqtt-username,len=34
[404] CrR:pdata=default-mqtt-password,len=34
[408] CrR:pdata=default-mqtt-SubTopic,len=34
[412] CrR:pdata=default-mqtt-PubTopic,len=34
[416] OK
[417] CrCCsum=0x29a6,CrRCsum=0x29a6
[420] Valid Stored Dynamic Data
[423] Hdr=SSL_ESP8266,BrdName= ESP8266_NODEMCU_ESP12E
[428] SSID=HueNet1,PW=password
[430] SSID1=HueNet2,PW1=password
[433] Server=account.duckdns.org,Token=token
[439] Server1=account.duckdns.org,Token1=token1
[446] Port=9443
[447] ======= End Config Data =======
[451] Check if isForcedCP
[457] LoadCPFile
[457] OK
[457] bg: noConfigPortal = true
[458] Connecting MultiWifi...
[5572] WiFi connected after time: 1
[5572] SSID: HueNet1, RSSI = -42
[5572] Channel: 2, IP address: 192.168.2.135
[5572] bg: WiFi OK. Try Blynk
[5574]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v1.0.0 on ESP8266_NODEMCU_ESP12E
[6589] NTP time: Wed May 26 18:39:36 2021
[6621] Connecting to account.duckdns.org:9443
[7388] Certificate OK
[7404] Ready (ping: 9ms).
[7491] Connected to Blynk Server = account.duckdns.org, Token = token
[7491] bg: WiFi+Blynk OK
Blynk ESP8266 using LittleFS connected.
Board Name :  ESP8266_NODEMCU_ESP12E
B
Your stored Credentials :
MQTT Server = default-mqtt-server
Port = 1883
MQTT UserName = default-mqtt-username
MQTT PWD = default-mqtt-password
Subs Topics = default-mqtt-SubTopic
Pubs Topics = default-mqtt-PubTopic
Stop multiResetDetecting
B
ESP32WM_MRD_ForcedConfig using LITTLEFS with SSL on ESP32_DEV
Starting ESP32WM_MRD_ForcedConfig using LITTLEFS with SSL on ESP32_DEV
Blynk_WM SSL for ESP32 v1.6.0
[227] Set CustomsStyle to : <style>div,input{padding:5px;font-size:1em;}input{width:95%;}body{text-align: center;}button{background-color:blue;color:white;line-height:2.4rem;font-size:1.2rem;width:100%;}fieldset{border-radius:0.3rem;margin:0px;}</style>
[249] Set CustomsHeadElement to : <style>html{filter: invert(10%);}</style>
[256] Set CORS Header to : Your Access-Control-Allow-Origin
[699] Hostname=ESP32-Master-Controller
[739] LoadCfgFile
[747] OK
[747] ======= Start Stored Config Data =======
[747] Hdr=SSL_ESP32,BrdName= ESP32_DEV
[747] SSID=HueNet1,PW=password
[748] SSID1=HueNet2,PW1=password
[751] Server=account.duckdns.org,Token=token
[757] Server1=account.duckdns.org,Token1=token1
[763] Port=9443
[765] ======= End Config Data =======
[768] CCSum=0x38ec,RCSum=0x38ec
[787] LoadCredFile
[794] CrR:pdata=default-mqtt-server,len=34
[794] CrR:pdata=1883,len=6
[794] CrR:pdata=default-mqtt-username,len=34
[794] CrR:pdata=default-mqtt-password,len=34
[797] CrR:pdata=default-mqtt-SubTopic,len=34
[801] CrR:pdata=default-mqtt-PubTopic,len=34
[805] OK
[806] CrCCsum=0x29a6,CrRCsum=0x29a6
[809] Valid Stored Dynamic Data
[812] Hdr=SSL_ESP32,BrdName= ESP32_DEV
[817] SSID=HueNet1,PW=password
[820] SSID1=HueNet2,PW1=password
[822] Server=account.duckdns.org,Token=token
[829] Server1=account.duckdns.org,Token1=token1
[835] Port=9443
[836] ======= End Config Data =======
[840] Check if isForcedCP
[861] LoadCPFile
[868] OK
[868] bg: noConfigPortal = true
[868] Connecting MultiWifi...
[13192] WiFi connected after time: 1
[13192] SSID: HueNet1, RSSI = -26
[13193] Channel: 2, IP address: 192.168.2.136
[13193] bg: WiFi OK. Try Blynk
[13194]
    ___  __          __
        /___/ v1.0.0 on ESP32_DEV
[14209] NTP time: Wed May 26 18:36:06 2021
[14209] Connecting to account.duckdns.org:9443
[16086] Certificate OK
[16095] Ready (ping: 8ms).
[16164] Connected to Blynk Server = account.duckdns.org, Token = token
[16164] bg: WiFi+Blynk OK
Blynk ESP32 using LittleFS connected
Board Name :  ESP32_DEV
B
Port = 1883
