Would it be possible that the app always keep the messages in the terminal widget when the app is closed and restarted? Maybe a command to clear the windows if/when needed?
This is possible. But will be done only after other issues with higher priority.
I’d like to float this idea back up to the top. I’ve been using terminal as a kind of event log in the app for my house HVAC (app is almost always on) but if the app crashes, reset, etc., I lose the event log. Or maybe a “log widget” would be a useful addition: User-customizable dimension (in the app) that just holds whatever you print there. I messed with using Twitter in this way but like having everything in the Blynk app. Thanks.
New ideas should be posted as a new topic. Otherwise, it will be buried in the forum.
Is there a way to keep the messages in the Terminal widget for when the app is closed?
Created ticket for that - https://github.com/blynkkk/blynk-server/issues/200 we will try implement in 0.16.0 version.
Thank you. Same problem has the Graph Widget …
