Terminal Widget commands
Dear Sirs,
I experimenting with the terminal widget and I have a question. Are there commands that terminal recognize? For example is there command to get clear the terminal contents? (the widget area on blynk app). Is there other commands that I can use?
Thanks and Best Regards,
Mike Kranidis
The terminal widget doesn’t support commands itself. It’s job is simply to pipe messages to the arduino and back. It’s up to you to program the arduino to respond to commands. It might help to look at this example: https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/Terminal/Terminal.ino
Dear Gaff,
Thanks for your answer.
As I stated, I have already implement terminal in some test scenarios successful. My question was / is regarding the so called “manipulation commands” like “terminal.clear”. That is the point. From blynk app perspective, it is very easy to implement this kind of terminal screen clearing…
Best Regards,
Mike Kranidis
@mikekgr at the moment terminal doesn’t support this, so it has no other commands except print
Thanks a lot Dear Dmitriy.
